Issues connecting to VPS
Hi, unfortunately I'm having trouble connecting to a VPS with WinSCP (and I'm new to using WinSCP). I get this error:
Unexpected directory listing line 'vps:/# total 84'. Invalid rights description 'ps:/# tot'
I've read the other posts on the boards and the supports docs:
https://winscp.net/eng/docs/requirements
https://winscp.net/eng/docs/ui_login_scp#shell
But, I'm still confused. From what I've read I think it's an issue with either the shell or the directory listing command. I think it could be that my shell opens with "vps:/#" but I'm not sure how to remedy this.
After executing ls -la, I get this:
vps:/# ls -la
total 84
drwxr-xr-x 20 root root 4096 Apr 20 22:19 .
drwxr-xr-x 20 root root 4096 Apr 20 22:19 ..
-rw------- 1 root 500 1024 Apr 20 22:19 .rnd
lrwxrwxrwx 1 root 500 39 Apr 20 22:19 aquota.group -> /proc/vz/vzaquota/000000e1/aquota.group
lrwxrwxrwx 1 root 500 38 Apr 20 22:19 aquota.user -> /proc/vz/vzaquota/000000e1/aquota.user
drwxr-xr-x 2 root root 4096 May 18 2009 bin
drwxr-xr-x 2 root root 4096 May 18 2009 boot
drwxr-xr-x 4 root root 4096 Apr 20 22:19 dev
drwxr-xr-x 70 root root 4096 Apr 21 19:19 etc
drwxr-xr-x 3 root root 4096 Apr 21 19:07 home
drwxr-xr-x 10 root root 12288 Apr 21 18:54 lib
drwxr-xr-x 2 root root 4096 May 18 2009 media
drwxr-xr-x 2 root root 4096 May 18 2009 mnt
drwxr-xr-x 2 root root 4096 May 18 2009 opt
dr-xr-xr-x 42 root root 0 Apr 20 22:19 proc
drwxr-xr-x 2 root root 4096 Apr 21 19:45 root
drwxr-xr-x 2 root root 4096 Apr 21 18:54 sbin
drwxr-xr-x 2 root root 4096 May 18 2009 selinux
drwxr-xr-x 2 root root 4096 May 18 2009 srv
drwxr-xr-x 3 root root 0 Apr 20 22:19 sys
drwxrwxrwt 4 root root 4096 May 12 18:09 tmp
drwxr-xr-x 11 root root 4096 May 18 2009 usr
drwxr-xr-x 14 root root 4096 May 12 02:35 var
Also, I've noticed people recommending changing "Alias LS to display group name" but I can't find that setting at all.
https://winscp.net/forum/viewtopic.php?t=32
Any help is much appreciated.
Re: Issues connecting to VPS
