Error when using sftp a file to OpenSolaris0906 client.
Agent
When I'm using an sftp connection to an OpenSolaris 0906 client with winscp 3.7 I'm getting the following error message:
Transfer was succesfully finished, but temporary transfer file 'filename.filepart' could not be renamed to target file name 'filename'. If the problem persists, you may try to turn off transfer resume support. General failure (server should provide error description). Error code: 4 Error message from server: Failure Request code: 18
Even if I turn off resume support in winscp settings the error message still comes up.
Getting the same error when trying to rename a remote file:
Error code: 4
Request code: 18
Any idea why this happens on OSOL only while the same approach on different flavours of Linux works fine?
Regards Agent
Re: Error when using sftp a file to OpenSolaris0906 client.
Please post a full log file showing that.
