Command line using private key
Frustrated
FYI - this works fine using the GUI interface. fails when I try and run it in batch mode.
Here is my command:
c:\pce\winscp.com scp://macsql2@www.pcesystems.com /privatekey=private.ppk
Here is the results:
C:\PCE>c:\pce\winscp.com scp://macsql2@www.pcesystems.com /privatekey=private.ppk  /script=c:\pce\script.txt
Automatic actions are disabled when URL address is provided on command-line.
Searching for host...
Connecting to host...
Authenticating...
Using username "macsql2".
Authenticating with public key "rsa-key-20100127".
Authenticated.
Starting the session...
Connection has been unexpectedly closed. Server sent command exit status 1.
Error skipping startup message. Your shell is probably incompatible with the app
lication (BASH is recommended).
Last thing, how do I have it automatically get my file once it's connected?
script.txt example:
get datamactest.zip
thanks
quit
Re: command line using private key
First, use open session command, do not specify the session on command-line for scripting.
Then, post a log files both for GUI and script.
Guest From Toronto
Trying to run command line script from SQL Server job
I am trying to execute following script from SQL Server Job to upload file.
declare @ftpcmd varchar(2000)
SELECT @ftpcmd = 'D:\WORK\FTP-SYNC\FTPClient\winscp556\WinSCP.com ftp://username:pwd@files.demosite.com /timeout=60  /console /command  "option confirm off " "put D:\Work\Calendar\calendar.pdf /_sitecalendar/"  "exit"  /log=D:\WORK\FTP-SYNC\LOG_Calendar.txt /y '
It fails to upload file with output result as
Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
Connecting to files.demosite.com ...
Connected with files.demosite.com. Waiting for welcome message...
Connected
Reading remote directory...
Session started.
Active session: [1] username@files.demosite.com
winscp>
NULL
Any help will be appreciated.
Thanks.
Re: Trying to run command line script from SQL Server job
The same problem as above.
You even get a hint:
The syntax you are using is wrong.
  • Use open command, do not specify the session URL as command-line parameter for scripting (the primary problem)
  • The /console has no effect when using winscp.com
  • There's no /y switch.
So it should be:
D:\WORK\FTP-SYNC\FTPClient\winscp556\WinSCP.com /command "open ftp://username:pwd@files.demosite.com -timeout=60" "put D:\Work\Calendar\calendar.pdf /_sitecalendar/" "exit" /log=D:\WORK\FTP-SYNC\LOG_Calendar.txt
