Change Date Format Display
Holodyn
Atlanta, GA
Would be nice =)
When there's a lot happening on the screen I like to shrink WinSCP and work to the side.
It would be nice if there was a date display format option so that a shorter format could be displayed.
Great work - WinSCP makes our job much more efficient!
Cheers
_________________
David R. Hunt
Holodyn Corporation
Web Application Development, Web Design, Graphic Design
holodyn.com, webuddha.com, liquidsquidstudios.com
Re: Change Date Format Display
WinSCP follows system date-time format. So you can change the format in Windows control panel.
