Multithreaded encryption
Re: Multithreaded encryption
Thanks for your hint. Though WinSCP uses SSH implementation from PuTTY, so unless they implement it, it won't get into WinSCP.
drwilco
The problem I see with that is that PuTTY doesn't really have a need for high performance as much as WinSCP does. And has PuTTY seen any updates the past 3 years? Is there any development being done at all on PuTTY?
