How to use the -permisssions switch in a bach file
Manu
I'm trying this in a batch file called by winscp.com :
synchronize remote "D:\local_directory" /remote_directory -delete -criteria=time -permissions=0640
Works fine, but permissions are not applied, while i can change them manually when using winscp in user interface mode.
Am i setting the permissions switch the right way ?
Thanks.
Re: How to use the -permisssions switch in a bach file
I believe you are.
Manu
Martin, I have sent you an email with the WinSCP's log file.
