(ECommand) Error getting name of current remote directory.
Anonymous1
We are using WinSCP Version 4.2.7 (Build 758). Our connnection type is FTPS: Implicit SSL/TLS.
After establishing a connection we get this error: (ECommand) Error getting name of current remote directory.
Invalid response to PWD command 'Command Okay.
Why is this happening?
Re: (ECommand) Error getting name of current remote directory.
