sudo implementation
mtschumi
sudo implementation
Hi fellers,
Would it be possible to implement a feature in the connection panel in order to execute a sudo su - user2 switch in order to use WINSCP also in case of sudo implementation on Unix boxes.
The idea is that the scp session then gets changed to the user2 because user 2 has more priviledges.
What do you think ?
Rgs
Michael
