Regression in 3.4.2 (build 197) with '~ ' at begging of directory name
joelhock
This worked fine with WinSCP 3.3, but is broken in 3.4.2:
If a directory begins with a tilde and space (e.g. ~ upload), then trying to descend into that directory will just take the use to their home directory.
I'm using SSH version 2, SCP protocol, compression and 3DES encryption. Here is part of the logfile that shows the problem (note that the directory I end up in is /home/joel, not the ~ upload directory).
Directory content loaded from cache.
Changing directory to "~ upload".
cd ~ upload ; echo "WinSCP: this is end-of-file:$?"
WinSCP: this is end-of-file:0
Getting current directory name.
pwd ; echo "WinSCP: this is end-of-file:$?"
/home/joel
Thanks for your wonderful program – it totally rocks!
Joel
Re: regression in 3.4.2 (build 197) with '~ ' at beggin of directory name
The problem was caused by fact that since 3.4.2, WinSCP down not add quotes around paths that begin with ~, to allow processing paths like ~prikryl (e.g. to open home directory of user prikryl). I may override this behaviour when second character is space, but I'm not sure, if this solves all possible cases. What do you think?
