WinSCP in fully potable configuration and portaPuTTY
maiux
Hello. I use both WinSCP (fully portable mode) and PortaPuTTY.
Integration fails: opening a WinSCP temporary session in PortaPuTTY will result in PortaPuTTY's configuration dialog.
I think I diagnosed the problem: PortaPuTTY stores sessions in .ini files put in .putty folder near the putty.exe
It will ignore the registry session data. How come out from this issue?
For reference: <invalid hyperlink removed by admin>
Many thanks
Re: WinSCP in fully potable configuration and portaPuTTY
WinSCP does not support with format of PuTTY configuration.
