Parameters not working for encryption type
JimGriffith
I'm trying to setup a script that specifies an explicit connection using port 21. If I use ftps in the session it tries to connect over 990. If I use ftp it tries to connect with no encryption. I've tried putting the parameters in multiple places with the same results.
script:
open ftps:user:pass@ftps.siteaddress.com /passive /explicitssl
option transfer binary
Results: connects to 990 using implicit encryption
script:
open ftp:user:pass@ftps.siteaddress.com /passive /explicitssl
results: connection via port 21 with no encryption
I've tried putting in the command line in different places as well
winscp.exe /script=c:\script.txt /passive /explicitssl /log=c:\log.txt
winscp.exe /passive /explicitssl /script=c:\script.txt /log=c:\log.txt
winscp.exe /script=c:\script.txt /log=c:\log.txt /passive /explicitssl
It appears to be ignoring the passive and encryption parameters and relying strictly on the protocol for it's connection method. Any suggestions? Thanks!
Reply with quote E-mail
Re: Parameters not working for encryption type
Sorry, not having enough time to read this carefully. What is this different to the problem we have already solved?
