setgid bit always unset when changing file permissions
berthierp
My Setup:
WinSCP 4.2.7 build 758 Running on Windows XP SP3.
SFTP session.
I am using directories with setgid bit set. I want to change the permissions of newly created directories to give write permission to the group (by default they have not). For this I right-click on the directory and change the permissions from the Properties dialog.
When I change the permissions of a directory that way, the setgid bit gets removed. In fact, there is no way to set the setgid bit, it just always gets turned off, whatever operation one does on permissions.
I have found a workaround by creating a custom command that executes chmod -R g+w "!" and applies on directories. This works fine.
Re: setgid bit always unset when changing file permissions
It is possible that your SFTP server does not support the setgit bit and silently ignores the request to set it.
berthierp
I believe our server supports that bit very well, because we use that feature for years now (running Suse enterprise / openSuse).
Apparently does not ignore the request because the bit gets unset every time that I change any other permissions using WinSCP. If the bit was set, it gets unset, and if the bit was not set, no change. My thought was that WinSCP would force the bit to unset every time.
I believe your server OS does, but your SFTP server does not.
It does not.
berthierp
Yes you are right, we were using a openssh 4.6 server, which is know to have this Bug ( https://bugzilla.mindrot.org/show_bug.cgi?id=1310 ). Using another openssh version 5.2 fixes the problem (apparently it has been fixed in 5.1).
Thanks for the help!
