Problem with upload file
yuranchik2
Hi
I can't uploa file over ssh. All files upload success, but one file with special name "%%7C^7C1^7C13AA49%%stats.tpl.php" uploads with problem. After upload, file name changed to "%|^7C1^7C13AA49%%stats.tpl.php". I must rename this file after every upload all files.
I try not olny one ssh server, with other ssh server, i have same bug.
WinSCP version is 4.2.7
Thanks.
Re: Problem with upload file
