Cannot login when home directory doesn't exist
psl
WinSCP 3.4.2: Home directory was set to /tmp/olc. I can login, until this directory exists. When directory is deleted, WinSCP cannot login. I don't know how to change home directory.
Could be WinSCP fixed in some way, to try parent directory, than pareny directory, until root directory? Or to ask user by prommpt for a home directory.
Re: Cannot login when home directory doesn't exist
When remote directory does not exist, error message should be displayed and default (home) directory should be opened. What exacly happes to you? Can you send me a log file?
. WinSCP Version 3.4.2 (Build 197)
. Login time: 19. prosinec 2003 21:38:10
. Session name: root@10.2.48.111a
. Host name: 10.2.48.111 (Port: 22)
. User name: root (Password: Yes, Key file: No)
. Transfer Protocol: SCP
. Agent forwarding: No; TIS/CryptoCard: No; KI: Yes
. Ping interval: 0 sec (0 = off); Timeout: 15 sec
. SSH Bugs: -,-,-,-,-,-,-,-,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: C:\Documents and Settings\slansky\Dokumenty, Remote directory: /tmp/test, Update: No, Cache: Yes
. Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. Looking up host "10.2.48.111"
. Connecting to 10.2.48.111 port 22
. Server version: SSH-1.99-OpenSSH_3.7.1p2
. We claim version: SSH-2.0-WinSCP-release-3.4.2.197
. Host key fingerprint is:
. ssh-rsa 1024 00:06:29:24:3d:c2:e0:68:96:20:b5:87:c0:1d:69:17
! Using username "root".
. Keyboard-interactive authentication refused
. Session password prompt (root@10.2.48.111's password: )
. Using stored password.
. Sent password
. Access granted
. Opened channel for session
. Started a shell/command
. Using SCP protocol.
. Skipping host startup message (if any).
> echo "WinSCP: this is end-of-file:0"
< Sun Microsystems Inc. SunOS 5.8 Generic Patch December 2002
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
> unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< other root bin sys adm uucp mail tty lp nuucp daemon ncoadmin
. Following groups found:
. other
. root
. bin
. sys
. adm
. uucp
. mail
. tty
. lp
. nuucp
. daemon
. ncoadmin
. Changing directory to "/tmp/test".
> cd "/tmp/test" ; echo "WinSCP: this is end-of-file:$?"
! -sh: /tmp/test: does not exist
. Waiting for data timed out, asking user what to do.
. Asking user:
. Host hasn't answered for 15 seconds.
. Wait for another 15 seconds? Pressing 'Abort' button will close session. ()
. Asking user:
. Attempt to close connection due to fatal exception:
* Terminated by user.
. Closing connection.
* (ESshFatal) Error changing directory to '/tmp/test'.
What is your shell? Some shells closes non-interactive session, when any error occures. BASH is recommended for WinSCP. Or try SFTP instead of SCP.
