Script can't find certain files
equimax
I am running WinSCP 4.2.7 build 758 on WinXP Pro SP3. I have a script which runs from a batch file which works just fine except certain files are reported as non-existent when they actually exist. Here is the script (weblists.bat) with password removed for security:
# Automatically answer all prompts negatively not to stall
# the script on errors
 option batch on
# Connect using a password
 open equimax:password@equimax.com
# Change remote directory
cd /htdocs/equimax/home
# Force binary mode transfer
option transfer binary
# Upload file to the remote directory
put c:\netfiles\weblists\weblists.zip
put c:\netfiles\weblists\C_LIST_D.php
put c:\netfiles\weblists\CANDS_D.PHP
put c:\netfiles\weblists\CLIENTS_D.PHP
put c:\netfiles\weblists\J_LIST_D.PHP
put c:\netfiles\weblists\JLSUB_D.PHP
put c:\netfiles\weblists\JOBS_D.PHP
put c:\netfiles\weblists\LISTCAND_D.PHP
put c:\netfiles\weblists\RECTS_D.PHP
put c:\netfiles\weblists\empnojob.txt
# Disconnect
close
# Exit WinSCP
The batch file command which runs this script is:
"c:\program files\winscp3\winscp.com" /script=c:\netfiles\scpscripts\weblists.txt
The files named weblists.zip and empnojob.txt transfer just fine. The others cannot be found. Here are the results as shown in the command window:
C:\Documents and Settings\Seth>"c:\program files\winscp3\winscp.com" /script=c
batch           on
confirm         off
Searching for host...
Connecting to host...
Authenticating...
Using username "equimax".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] equimax@equimax.com
transfer        binary
c:\...\WEBLISTS.ZIP       |        219 KiB |   37.6 KiB/s | binary | 100%
File or folder 'c:\netfiles\weblists\C_LIST_D.php' does not exist.
System Error.  Code: 2.
The system cannot find the file specified
File or folder 'c:\netfiles\weblists\CANDS_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\CLIENTS_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\J_LIST_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\JLSUB_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\JOBS_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\LISTCAND_D.PHP' does not exist.
File or folder 'c:\netfiles\weblists\RECTS_D.PHP' does not exist.
c:\...\empnojob.txt       |          0 KiB |    0.0 KiB/s | binary | 100%
Session 'equimax@equimax.com' closed.
No session.
Anyone know why the PGP files are not being found? I have tried putting path in quotes, tried sending files without underscores.
Stumped. :?
Re: Script can't find certain files
If you run WinSCP GUI and navigate to the folder, do you see the files? Can you upload them?
mrx
No automatic retry
I'm running the same version. The problem is that I have the following problem while running the copy-script (from a remote server to a local machine) from time to time:
3.png     |          4 KiB |    6.7 KiB/s | binary | 100%
4.png     |          0 KiB |    3.2 KiB/s | binary |   0%
Error transferring file '/folder2/folder.loc/web/4.png'.
Copying files from remote side failed.
Can't open data connection.
Session 'test' closed.
No session.
And next time the process could go with no errors at all. So how can I use (R)etry-option instead of default (A)bort one? I checked up with the settings and didn't find anything about it so far. Thank you.
mrx
And I am not sure if this works:
Bug fix: When file transfer failed with FTP protocol, whole batch was interrupted, without an option to retry or skip the file transfer.
It happens again and again for different servers and different files and with the same error - can't open data connection and then the session gets closed instead of retrying/skipping file copying automatically. If it is fixed, please, tell me how explicitly to turn that option on in a script or ini-file. Thank you.
equimax
Yes. Thanks for looking into this for me.
Here is the log file for the GUI.
. 2010-03-29 10:10:17.868 Copying 1 files/directories to remote directory "/htdocs/equimax/home/"
. 2010-03-29 10:10:17.878   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2010-03-29 10:10:17.878   TM: M; ClAr: No; CPS: 0; ExclM(No):
. 2010-03-29 10:10:17.878   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-03-29 10:10:17.878 File: "C:\netfiles\weblists\CANDS_D.PGP"
. 2010-03-29 10:10:18.258 Copying "C:\netfiles\weblists\CANDS_D.PGP" to remote directory started.
. 2010-03-29 10:10:18.278 Binary transfer mode selected.
. 2010-03-29 10:10:18.288 Checking existence of file.
> 2010-03-29 10:10:18.288 Type: SSH_FXP_LSTAT, Size: 41, Number: 1543
< 2010-03-29 10:10:18.288 Type: SSH_FXP_STATUS, Size: 24, Number: 1284
. 2010-03-29 10:10:18.288 Discarding reserved response
< 2010-03-29 10:10:18.358 Type: SSH_FXP_STATUS, Size: 29, Number: 1543
< 2010-03-29 10:10:18.358 Status code: 2
. 2010-03-29 10:10:18.358 Checking existence of partially transfered file.
> 2010-03-29 10:10:18.358 Type: SSH_FXP_LSTAT, Size: 50, Number: 1799
< 2010-03-29 10:10:18.419 Type: SSH_FXP_STATUS, Size: 29, Number: 1799
< 2010-03-29 10:10:18.419 Status code: 2
. 2010-03-29 10:10:18.419 Opening remote file.
> 2010-03-29 10:10:18.419 Type: SSH_FXP_OPEN, Size: 66, Number: 2051
< 2010-03-29 10:10:18.509 Type: SSH_FXP_HANDLE, Size: 13, Number: 2051
> 2010-03-29 10:10:18.639 Type: SSH_FXP_WRITE, Size: 4121, Number: 2566
. 2010-03-29 10:10:50.675 82 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-03-29 10:10:50.685 Type: SSH_FXP_CLOSE, Size: 13, Number: 13572
< 2010-03-29 10:10:50.695 Type: SSH_FXP_STATUS, Size: 24, Number: 12806
< 2010-03-29 10:10:52.267 Type: SSH_FXP_STATUS, Size: 24, Number: 13062
< 2010-03-29 10:10:52.387 Type: SSH_FXP_STATUS, Size: 24, Number: 13318
< 2010-03-29 10:10:52.387 Type: SSH_FXP_STATUS, Size: 24, Number: 13572
< 2010-03-29 10:10:52.387 Status code: 0
> 2010-03-29 10:10:52.457 Type: SSH_FXP_RENAME, Size: 86, Number: 13842
< 2010-03-29 10:10:52.528 Type: SSH_FXP_STATUS, Size: 24, Number: 13842
< 2010-03-29 10:10:52.528 Status code: 0
> 2010-03-29 10:10:52.528 Type: SSH_FXP_SETSTAT, Size: 53, Number: 2313
< 2010-03-29 10:10:52.598 Type: SSH_FXP_STATUS, Size: 24, Number: 2313
< 2010-03-29 10:10:52.808 Status code: 0
. 2010-03-29 10:10:52.828 Listing directory "/htdocs/equimax/home".
> 2010-03-29 10:10:52.828 Type: SSH_FXP_OPENDIR, Size: 29, Number: 14091
< 2010-03-29 10:10:52.888 Type: SSH_FXP_HANDLE, Size: 13, Number: 14091
> 2010-03-29 10:10:52.888 Type: SSH_FXP_READDIR, Size: 13, Number: 14348
< 2010-03-29 10:10:52.958 Type: SSH_FXP_NAME, Size: 573, Number: 14348
> 2010-03-29 10:10:52.958 Type: SSH_FXP_READDIR, Size: 13, Number: 14604
< 2010-03-29 10:10:53.058 Type: SSH_FXP_STATUS, Size: 28, Number: 14604
< 2010-03-29 10:10:53.229 Status code: 1
> 2010-03-29 10:10:53.229 Type: SSH_FXP_CLOSE, Size: 13, Number: 14852
Now here is the log file for the command line transfer.
. 2010-03-29 10:28:19.483 --------------------------------------------------------------------------
. 2010-03-29 10:28:19.483 WinSCP Version 4.2.7 (Build 758) (OS 5.1.2600 Service Pack 3)
. 2010-03-29 10:28:19.483 Login time: Monday, March 29, 2010 10:28:19 AM
. 2010-03-29 10:28:19.483 Session name: equimax@equimax.com
. 2010-03-29 10:28:19.483 Host name: equimax.com (Port: 13140)
. 2010-03-29 10:28:19.483 User name: equimax (Password: Yes, Key file: No)
. 2010-03-29 10:28:19.533 Tunnel: No
. 2010-03-29 10:28:19.533 Transfer Protocol: SFTP (SCP)
. 2010-03-29 10:28:19.533 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-03-29 10:28:19.533 Proxy: none
. 2010-03-29 10:28:19.533 SSH protocol version: 2; Compression: No
. 2010-03-29 10:28:19.533 Bypass authentication: No
. 2010-03-29 10:28:19.533 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-03-29 10:28:19.533 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-03-29 10:28:19.533 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-03-29 10:28:19.533 SFTP Bugs: -,-
. 2010-03-29 10:28:19.533 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-03-29 10:28:19.533 Shell: default, EOL: 0
. 2010-03-29 10:28:19.533 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-03-29 10:28:19.533 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-03-29 10:28:19.533 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-03-29 10:28:19.533 Cache directory changes: Yes, Permanent: Yes
. 2010-03-29 10:28:19.533 DST mode: 1
. 2010-03-29 10:28:19.533 --------------------------------------------------------------------------
. 2010-03-29 10:28:19.533 Looking up host "equimax.com"
. 2010-03-29 10:28:19.813 Connecting to 69.93.63.14 port 13140
. 2010-03-29 10:28:20.094 Server version: SSH-2.0-OpenSSH_5.2
. 2010-03-29 10:28:20.094 Using SSH protocol version 2
. 2010-03-29 10:28:20.094 We claim version: SSH-2.0-WinSCP_release_4.2.7
. 2010-03-29 10:28:20.164 Doing Diffie-Hellman group exchange
. 2010-03-29 10:28:20.314 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-03-29 10:28:20.825 Host key fingerprint is:
. 2010-03-29 10:28:20.825 ssh-rsa 1024 ac:6d:be:2d:0c:2a:b2:a3:a4:73:c4:42:f6:77:e5:ec
. 2010-03-29 10:28:20.835 Initialised AES-256 SDCTR client->server encryption
. 2010-03-29 10:28:20.835 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-03-29 10:28:20.835 Initialised AES-256 SDCTR server->client encryption
. 2010-03-29 10:28:20.835 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-03-29 10:28:20.965 Using username "equimax".
. 2010-03-29 10:28:21.165 Prompt (6, SSH password, , &Password: )
. 2010-03-29 10:28:21.165 Using stored password.
. 2010-03-29 10:28:21.175 Sent password
. 2010-03-29 10:28:21.616 Access granted
. 2010-03-29 10:28:21.676 Opened channel for session
. 2010-03-29 10:28:21.826 Started a shell/command
. 2010-03-29 10:28:21.836 --------------------------------------------------------------------------
. 2010-03-29 10:28:21.836 Using SFTP protocol.
. 2010-03-29 10:28:21.836 Doing startup conversation with host.
> 2010-03-29 10:28:21.836 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-03-29 10:28:21.896 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2010-03-29 10:28:21.896 SFTP version 3 negotiated.
. 2010-03-29 10:28:21.896 We believe the server has signed timestamps bug
. 2010-03-29 10:28:21.896 We will use UTF-8 strings for status messages only
. 2010-03-29 10:28:21.896 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-03-29 10:28:21.906 Getting current directory name.
. 2010-03-29 10:28:21.906 Getting real path for '.'
> 2010-03-29 10:28:21.906 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
< 2010-03-29 10:28:21.957 Type: SSH_FXP_NAME, Size: 47, Number: 16
. 2010-03-29 10:28:21.957 Real path is '/home/equimax'
. 2010-03-29 10:28:21.957 Startup conversation with host finished.
. 2010-03-29 10:28:21.967 Cached directory change via "/htdocs/equimax/home" to "/htdocs/equimax/home".
. 2010-03-29 10:28:21.967 Getting current directory name.
. 2010-03-29 10:28:21.997 Copying 1 files/directories to remote directory "/htdocs/equimax/home"
. 2010-03-29 10:28:21.997   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask:
. 2010-03-29 10:28:21.997   TM: B; ClAr: No; CPS: 0; ExclM(No):
. 2010-03-29 10:28:21.997   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2010-03-29 10:28:21.997 File: "c:\netfiles\weblists\CANDS_D.PHP"
* 2010-03-29 10:28:21.997 (EOSError) System Error.  Code: 2.
* 2010-03-29 10:28:21.997 The system cannot find the file specified
. 2010-03-29 10:28:21.997 Asking user:
. 2010-03-29 10:28:21.997 File or folder 'c:\netfiles\weblists\CANDS_D.PHP' does not exist. ("System Error.  Code: 2.
. 2010-03-29 10:28:21.997 The system cannot find the file specified")
* 2010-03-29 10:28:22.027 (EScpSkipFile) File or folder 'c:\netfiles\weblists\CANDS_D.PHP' does not exist.
* 2010-03-29 10:28:22.027 System Error.  Code: 2.
* 2010-03-29 10:28:22.027 The system cannot find the file specified
. 2010-03-29 10:28:22.047 Closing connection.
. 2010-03-29 10:28:22.047 Sending special code: 12
. 2010-03-29 10:28:22.047 Sent EOF message
equimax
Boy do I feel dumb. I work with PHP files so often that I completely missed the mistake, even though I looked at it multiple times. Thanks so much for solving the problem for me. Sorry to have bothered you.
Best Regards,
Seth
Hi I am new to WinSCP, I am using WinSCP with VB.NET.
I just want to download a file from remote directory to local directory (C:\Document And Settings), but I am below error.
Can't get attributes of file 'C:\Documents'.
No such file or directory.
Error code: 2
Error message from server: No such file
Request code: 7
Please suggest a solution. Thanks
Below is my code:
Private Function WinSCPDownload() As Boolean
    Try
        If (Login()) Then
            With WinSCP.StandardInput
                .WriteLine("cd /data/test/out")
                .WriteLine("ls *-International-*.xml")
                .WriteLine("get -nopreservetime *-International-*.* C:\Documents and settings\")
                  .Close()
            End With
        End If
    Catch ex As Exception
        Debug.WriteLine(ex.Message)
    End Try
End Function
Error:
winscp> cd /data/test/out
/data/test/out
winscp> ls *-International-*.xml
winscp> get -nopreservetime *-International-*.* C:\Documents and settings\
Error code: 2
Request code: 7
The program '[2628] WindowsApplicationJK.exe' has exited with code 0 (0x0).
