How to limit to a single SFTP session only?
Kirk Wolf
We have a SFTP server where we need to limit a given WinSCP user to a single ssh/sftp session.
Using WinSCP 4.1.9 Build 416, it seems to be impossible to prevent WinSCP from starting a second sftp session to the server for transfers. Is there a way around this?
Thanks,
Kirk Wolf
Kirk Wolf
BTW - if we can resolve this issue, we can probably get WinSCP to work with z/OS (MVS) including not only the z/OS Unix filesystem but also MVS datasets via SSH/SFTP.
Re: How to limit to a single SFTP session only?
What would prevent user to start another WinSCP instance? Or using another client?
You have to place such restrictions on the server side.
Kirk Wolf
The problem is this:
When using WinSCP to a z/OS server, there are a bunch of z/OS-specific file transfer settings that are outside the SFTP spec. With WinSCP, you can set these options by creating (or renaming) files in a pseudo directory (/+). It is no problem doing this from WinSCP.
The problem is that once you have set those options, they affect only that sftp session. So if WinSCP insists on starting a new sftp session for doing file transfers, then the options are lost.
This is why we would like to have a single WinSCP "session" only start a single sftp session to z/OS.
Thanks,
Kirk Wolf
OK, I see. But unfortunately, WinSCP does not support that any more.
