Moving entire directory tree using scripting
99as
I have a directory locally that I need to move remotely. I want to move the entire local tree using scp, from a windows box to a linux fc6 box. I can do this using the gui by dragging and dropping. I tried the following script:
synchronize remote "C:\temp\download" "/home/ets/tmp"
When I checked the linux box, all the files were copied to /home/ets/tmp rather than preserving the tree. What I want to see is the directory called firmware under c:\temp\download copied to /home/ets/tmp.
I looked also at the put command but that seems to require I give it a file list rather than a directory.
Any suggestions how I can accomplish this?
Re: Moving entire directory tree using scripting
synchronize preserves the three. I.e. directory C:\temp\download\firmware will become /home/ets/tmp/firmware. Do I understand right that you see files from C:\temp\download\firmware directly in /home/ets/tmp?
It supports both.
99as
For some reason, synchronize worked yesterday night. Thanks for the reply.
It supports both.
