Bug in Winscp-4.2.7 version with FTP port
Rasheed
I was installed Winscp-4.2.7 latest edition for windows-xp and trying to connect one of my AIX and HPUX servers using FTP port it is not connecting and hanging. But if i try with SFTP it is connecting.
Re: Bug in Winscp-4.2.7 version with FTP port
