WinSCP can't read directory structure
Gast
I alway receive an error message when WinSCP tries to get the directory structure:
Unexpected directory listing line 'insgesamt 10984'.
Invalid rights description 'nsgesamt '
I think that the last line is a summary of the bytes/bits that are to read, but don't know.
Possibly you should try to ignore the line:
insgesamt 10984????
Best Regards Mark
Re: WinSCP can't read directory structure
I just changed the protocol to SFTP and now it works.
Maybe it's an bug anyway. Don't know....
Very good tool, anyway!!!
Cheers
I have the same problem, but unfortunately the solution doesnot work: too big packet send.
The directory structure is asked by the command
ls -la
, is there a way to change into
ls -l
thanks...
This is usually caused by some message printed from .profile or similar script. Try to remove such messages, if any.
ls -la
ls -l
It is not possible.
