Add files to queue without starting a transfer
Laph
...is a highly required feature if you update Websites.
You (more or less) put a "change set" into the queue, and once you are done you hit a button to start transfering the queue.
Well, that's how FileZilla does it (and - to be honest - I really like that), but I'd wanna use WinSCP's Sync features.
Any chance to get such a feature in WinSCP?
Laph
Keith M
Status?
Is this still something that is in the works or has it been pushed to the back burner? I'm doing a site update right now and just thought about how this would be a very nice feature to have.
toolance
Add to Queue
Many FTP apps have this essential feature which makes updating multiple site folders much easier. Having to wait for one group of files to upload before you manually setup a different group of files to upload can be very tedious and means you are glued to the computer waiting for the uploads to finish.
Perhaps this function is already in WINSCP but I just don't know how to use it?
Guest123
See above
yeah this seems so simple??
why isn't this a feature?
Another thing that would be nice, once you are able to make a queue without starting the transfer, is to put a timer on it.
E.g: put file1, file2, and file3 in queue. And start the queue in 2h..
Re: See above
It has been implemented already. See the tracker link above.
https://winscp.net/tracker/29
Will consider.
