using WinSCP for anonymous ftp
CNBarnes
How can I use WinSCP3 to get files from an anonymous ftp server? It works fine connecting to the server if I use the userid/password I have on that machine, but when I try to use anonymous in the userid field, it rejects the password (of my email address).
Chris Banres
chris-barnes@tamu.edu
Re: using WinSCP for anonymous ftp
Keep in mind that WinSCP is not FTP client! It is SCP and SFTP client. In my opinion, anonymous SCP/SFTP is nonsense.
I can't say I disagree with your opinion, but as a developer on a government project only requirements matter. I have a requirement to access data from the anonymous FTP site of another government agency. I don't have the luxury of telling them how to do business. I don't have the option of ignoring a requirement. The product either supports anonymous FTP or it doesn't and we will have to use another method of meeting the requirement. Could you please answer the questions:
Does Winscp support anonymous FTP? (Yes or no)
If Winscp does support anonymous FTP, how does one script it?
Sorry if this is terse, but you have to understand that when you are looking for answers and all you get are opinions it is extremely frustrating.
To answer your question:
WinSCP does not support anonymous FTP. Althought some WinSCP works for some anonymous FTP sites, it doesn't work for many.
That's not true. See my previous post.
Scr
I can't connect to anymous ftp.
I try to connect to ftp://ftp1.mplayerhq.hu/ but i still prompted for password and then
Żądana nazwa jest prawidłowa i została znaleziona w bazie danych, ale dane, z kterymi jest skojarzona, są niepoprawne.
Connection failed.
But other ftp clients are connecting to it.
I'm using WinSCP 5.0. (build 1456).
KristiantheConqueror
Anonymous FTP Script Example
You can get it to work in a script by using anonymous as both the username and password.
open ftp://anonymous:anonymous@ftp.website.com:21
Haven't tested it against an SFTP site, but it worked fine against FTP.
Tested using WinSCP version 5.5.1.3970 on Windows Server 2008r2
