ask password, trying to reconnec and ask password again
Max
WinSCP 4.2.7
Steps:
1. connect to server over SCP (password do not saved)
2. do not touch it some long time
WinSCP ask enter passsword again
3. enter password
WinSCP show:
'Server close connection:
Using username "*".
Authentication failed.'
4. press Reconnect
it try reconnect and ask password again...
Can you do not ask password if WinSCP lost connection, or remember password from step 3?
thank you.
Re: ask password, trying to reconnec and ask password again
