synchronize command doesn't with -delete option
eddzzz
I would like to backup a directory to a server via the commandline. I got it working, but for some reason only without the delete option, which I really need.
What works is:
winscp.exe nbbackup /command "synchronize remote d:\nbbackup /nbbackup"
What does not work is:
winscp.exe nbbackup /command "synchronize remote d:\nbbackup /nbbackup -delete -mirror"
The second command doesn't work at all. It not only doesn't delete, but it also doesn't copy any files anymore.
What am I doing wrong?
Thanks.
eddzzz
There is no output to the screen when I enter command B, it just gives back a prompt.
Actually this is the same behaviour as when I enter command A, which also only gives back a promt. But then it does sync the two directories. Problem is that i need it to delete the removed files.
Run:
winscp.com nbbackup /command "synchronize remote d:\nbbackup /nbbackup -delete -mirror"
(note the .com extension)
