Installing Client Certificates for FTPS
Si1verfox
WinSCP v4.2.5 (Build624)
I am trying to use WinSCP as an FTPS (not SFTP) client with mutual authentication between the client and server.
When I attempt to login I receive and accept the server certificate but the connection is closed by the server as no client certificate is returned.
How do I set up WinSCP to either,
(i) prompt the user for a certifciate or
(ii) to automatically send a certificate: in which case how do I install the certificate?
Si1verfox
Anon
Re: Installing Client Certificates for FTPS
WinSCP does not support client certificates.
Is this still true? Are client certificates supported in any later versions of WinSCP?
Thanks.
Can you send me an email, so I can send you back a development version of WinSCP to test with? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
