WinSCP cannot open the ini file
Aro
Hello
I want open an ftp connection without encryption.
WinSCP aborts with the error message Cannot open file "path to the ini-file". The settings are stored in the ini-file.
I start WinSCP with /ini=IniFile and /log=LogFile, i try other settings with no logging.
The log contains the following:
connected
Using FTP protocol.
Attempt to close connection due fatal exception:
(EFOpenError) Cannot open file "path to ini-file"
(ESshFatalError) Cannot open file "path to ini-file"
connection aborted
the enviroment: Win7 x64, executed as administrator
Aro
Re: WinSCP cannot open the ini file
Yes.
I deleted the ini-file and started WinSCP as administrator.
The problem also occurs with SSH.
Aro
problem eliminated
The cause of the problem was the lnk-file, which i created to start WinSCP. I created a new lnk-file and now it works fine.
It is a strange problem, i can't reproduce it and there is no i difference between the settings.
Many thanks for your answers.
