error: server unexpectedly closed network connection
Roman Holiday
I keep getting this message when I try to log in. I'm not doing anything differently than I have in the past but now it just won't connect.
Re: error: server unexpectedly closed network connection
somebodyHH
error reproducable
Hi.
Having also the problem with "server unexpectedly closed network connection"
This Problem occurs in WinXP systems with SP3 running WinSCP Version 4.2.7
This Problem does not occur on similar systems running WinSCP Version 4.0.3
For testing I installed the WinSCP Version 4.2.7 on Systems whre V 4.0.3 worked without any issue and "tataa" connection droped !
So is this an issue with the newer Version or are there some default settings that changed to the prior version? I tried to figure out but couldn't find anything by changing WinSCP config to make it work!?!
Re: error reproducable
Sent email.
