Doing a "Touch" on the files in the remote directory
Arul
I need a script to do a "touch" on the files on the remote directory after FTP'ing the files over. Any scripts are welcome.
Re: Doing a "Touch" on the files in the remote directory
You can use "call" command. Are you indeed using FTP protocol? Or other?
Arul
I am using the sFTP protocol for transfer of files. How do I use the call statement in my script and how do Ido a Touch on the remote files. I am a newbie and an example would certainly help.
Most usually:
call touch file
