Error code 127
Bassanio
Error code 127
Cannot execute SCP to start transfer. Please make sure that SCP is installed on the server and path to it is included in PATH. You may also try SFTP instead of SCP.
Command failed with return code 127.
I realize this is probably a pretty dumbass question. But just how does one do this?
Re: Error code 127
To clarify the question, I mean how does one switch to SFTP mode?
Re: Error code 127
There's a switch on session tab of login dialog.
