wokaround for bad ftp server welcome message
markizs
i want to connect to odd ftp server, that has wrong welceme message format.
instead, of standards complying
220 (vsFTPd 1.1.3 bla bla)
it returns
Running the FTPD
                Got past fork
                             changed group
                                          opened tty
                                                    /home/directory/bla/bla/log
/system/ftpd.logdoing signal
                            signal
                                  listening
                                           220 strange FTP server (Version 5.437
 Fri Dec 24 08:39:24 CST 2004) ready.
which of course is completely non-standard and doesnt comply to ftp prodotocl.
however, i have actualy found one ftp client that manages to get 220 out of this mess, and after that everything works fine. This client is CuteFTP Pro. Problem is, that none of other ftp clients (windows default, windows commander, ultraedit built in, filezilla) i have tried, understands that, and i would really like to use open source client instead of expensive and bloated cuteftp.
So, question is - could it be possible to do some kind of workaround in winscp, using some script/configuration or whatever, to get through this odd welcome message?
Is there something i can do, apart of downloading source and building my own custom version of winscp client?
Re: wokaround for bad ftp server welcome message
markizs
. 2010-02-23 18:28:40.453 WinSCP Version 4.2.6 (Build 721) (OS 5.1.2600 Service Pack 3)
. 2010-02-23 18:28:40.453 Login time: otrdiena, 2010. gada 23. februāris 18:28:40
. 2010-02-23 18:28:40.453 --------------------------------------------------------------------------
. 2010-02-23 18:28:40.453 Session name: user@server.org
. 2010-02-23 18:28:40.453 Host name: server.org (Port: 7021)
. 2010-02-23 18:28:40.453 User name: user (Password: No, Key file: No)
. 2010-02-23 18:28:40.453 Tunnel: No
. 2010-02-23 18:28:40.453 Transfer Protocol: FTP
. 2010-02-23 18:28:40.453 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-23 18:28:40.453 Proxy: none
. 2010-02-23 18:28:40.453 FTP: FTPS: None; Passive: No [Force IP: No]
. 2010-02-23 18:28:40.453 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-02-23 18:28:40.453 Cache directory changes: Yes, Permanent: Yes
. 2010-02-23 18:28:40.453 DST mode: 1
. 2010-02-23 18:28:40.453 Password prompt (no password provided or last login attempt failed)
. 2010-02-23 18:28:44.796 Connecting to server.org:7021 ...
. 2010-02-23 18:28:45.093 Connected with server.org:7021. Waiting for welcome message...
. 2010-02-23 18:28:59.453 Timeout detected.
. 2010-02-23 18:28:59.453 Connection failed.
. 2010-02-23 18:28:59.453 Got reply 1004 to the command 1
* 2010-02-23 18:28:59.468 (ESshFatal) Connection failed.
* 2010-02-23 18:28:59.468 Timeout detected.
* 2010-02-23 18:28:59.468 Connection failed.
. 2010-02-23 18:29:04.468 Password prompt (no password provided or last login attempt failed)
* 2010-02-23 18:29:22.531 (ESshFatal) Authentication failed.
and as i posted in previous post - problem is on the server side, it sends bad welcome message. what i want to achieve is some workaround so winscp would ignore that.
Kieran
I also use this kind of server
I have no control over what welcome message the server sends as i am not admin, winscp is able to verify the ssl connection but is unable to comply with the welcome message.
Re: I also use this kind of server
Please attach a complete session log file.
