Synchronize folders and subdirectories
clopezbe
I have a problem with synchronization process (Remote to local), because the script ignore subfolders in remote directory.
option batch on
option batch continue
open user:pass@10.10.10.10
option transfer binary
synchronize local -mirror "C:\MyFolder\MyData" /data/SCANNER_IN/Data/
Please help me with us
[/code]
Re: Synchronize folders and subdirectories
clopezbe
I find the "root cause". The synchronization is done with files on the network, but the connection was closed with the shared resource.
At reconnecting to the shared folder, he returned to sync correctly.
Thanks a lot for your answers
CL.
