(ESshFatal) Disconnected: No supported authentication method
two7s_clash
Charlottesville, VA, USA
Just trying to make sure I'm doing everything right on my end -- can't connect to a SFTP site, admin insists I should be able to. However, I often connect to other servers with no issues...
I keep getting No supported authentication methods available
From my log:
. 2010-02-19 21:46:44.964 --------------------------------------------------------------------------
. 2010-02-19 21:46:44.964 WinSCP Version 4.2.4 (Build 610) (OS 5.1.2600 Service Pack 3)
. 2010-02-19 21:46:44.964 Login time: Friday, February 19, 2010 9:46:44 PM
. 2010-02-19 21:46:44.964 Session name: jamesf@xxxxxx.org
. 2010-02-19 21:46:44.964 Host name: xxxxxx.org (Port: 22)
. 2010-02-19 21:46:44.964 User name: jamesf (Password: Yes, Key file: No)
. 2010-02-19 21:46:44.964 Tunnel: No
. 2010-02-19 21:46:44.964 Transfer Protocol: SFTP (SCP)
. 2010-02-19 21:46:44.964 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2010-02-19 21:46:44.964 Proxy: none
. 2010-02-19 21:46:44.964 SSH protocol version: 2; Compression: No
. 2010-02-19 21:46:44.964 Bypass authentication: No
. 2010-02-19 21:46:44.964 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-02-19 21:46:44.964 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2010-02-19 21:46:44.964 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2010-02-19 21:46:44.964 SFTP Bugs: -,-
. 2010-02-19 21:46:44.964 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-02-19 21:46:44.964 Shell: default, EOL: 0
. 2010-02-19 21:46:44.964 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-02-19 21:46:44.964 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2010-02-19 21:46:44.964 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2010-02-19 21:46:44.964 Cache directory changes: Yes, Permanent: Yes
. 2010-02-19 21:46:44.964 DST mode: 1
. 2010-02-19 21:46:45.042 Looking up host "xxxxxx.org"
. 2010-02-19 21:46:45.042 Connecting to port 22
. 2010-02-19 21:46:45.120 Server version: SSH-2.0-OpenSSH_5.1p1 Debian-5
. 2010-02-19 21:46:45.120 Using SSH protocol version 2
. 2010-02-19 21:46:45.120 We claim version: SSH-2.0-WinSCP_release_4.2.4
. 2010-02-19 21:46:45.151 Doing Diffie-Hellman group exchange
. 2010-02-19 21:46:45.276 Doing Diffie-Hellman key exchange with hash SHA-1
. 2010-02-19 21:46:45.432 Host key fingerprint is:
. 2010-02-19 21:46:45.432 ssh-rsa 2048 34:a8:81:ce:e3:c6:8b:c9:4f:2b:d0:4f:95:d5:47:a3
. 2010-02-19 21:46:45.432 Initialised AES-256 SDCTR client->server encryption
. 2010-02-19 21:46:45.432 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-02-19 21:46:45.432 Initialised AES-256 SDCTR server->client encryption
. 2010-02-19 21:46:45.432 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-02-19 21:46:45.542 Using username "jamesf".
. 2010-02-19 21:46:45.776 Disconnected: No supported authentication methods available
* 2010-02-19 21:46:45.776 (ESshFatal) Disconnected: No supported authentication methods available
* 2010-02-19 21:46:45.776 Authentication log (see session log for details):
* 2010-02-19 21:46:45.776 Using username "jamesf".
* 2010-02-19 21:46:45.792
* 2010-02-19 21:46:45.792 Authentication failed.
Do I just need to be provided with a Public Key? Does a server setting need to changed?
Thanks for the advice.
Reply with quote E-mail
Re: (ESshFatal) Disconnected: No supported authentication method
Ask the server administrator for authentication method allowed on the server. Public key might be a solution.
