Log Connection Problem when using Automated Scripting.
jata
Hi
I am using Automated Scripts to using 'OPEN' command to connect to an SFTP Server. I turned off the SFTP Server to make sure that I dont connect to trap the connection Error. Who can I have the connection error be written to the XML Log file that I turned on.
JV
Re: Log Connection Problem when using Automated Scripting.
Do you mean that the connection failure does not get recorded in XML log?
jata
Yep.... When the connection is not established for whatever reason I dont see any indication in the XML Log File. Appreciate all your help.
JV
