save password bug
blackps
save password bug
Enter ftp, type a wrong password,save it,then enter the correct one and select "change saved password with this one" is not working,it will tell you it's a incorrect password and it will ask it again,change password is not working if you first enter a wrong one.
Re: save password bug
I wasn't able to reproduce that. Can you provide me a more detailed description of the steps as well as the log file?
