WinSCP cannot accept special characters (@ or %) in password
Farhana
I am using WINSCP3. In the script, if I use any special characters(.i.e @), it fails to upload. I am using hexadecimal ASCII code for special character, but still is not working
for an example:
pwd: abcd@123
and I changed to abcd%40123 in the script.
Could someone please tell me what's the correct procedure to use special characters in password in the script?
Many Thanks,
Farhana
Re: WinSCP cannot accept special characters (@ or %) in password
It works for me. What version of WinSCP are you using? Make sure you use the latest version.
Thanks for the quick reply! I am using 4.2.5. It does not take "%" or "/" as password. Could you please tell me which version are you using?
The same. Can you a post a full example of the script command. Also where do you run the command from? Script or command-line (with /command parameter)?
I am using Java to create the stript to synchronize local folder.
The java program takes the password as an input. I have created jar file for the program.
The following is the sample code:
ftpUrl = ftpLoginName + ":" + ftpLoginPass + "@" + ftpDomainUrl;
// Create file
fstream = new FileWriter("SiteExportImport3.cmd");
out = new BufferedWriter(fstream);
out.write("@echo off\r\n" +
"echo option batch on>SFTP_Script.txt\r\n" +
"echo option confirm off>>SFTP_Script.txt\r\n" +
"echo open " + ftpUrl + ">>SFTP_Script.txt\r\n" +
"echo option transfer binary>>SFTP_Script.txt\r\n" +
"echo synchronizelocal "+localDirectoryName+">>SFTP_Script.txt\r\n" +
"echo close >>SFTP_Script.txt\r\n" +
"echo exit>>SFTP_Script.txt\r\n" +
"call \"C:\\Program Files\\WinSCP\\WinSCP.com\" / hostkey=\"XXX\"/script=\"SFTP_Script.txt\">log.txt\r\n" );
out.close();
in the command prompt I execute the jar file with the parameter:
MYFTP.jar password
It works fine when I don't use "%" or "/" in my password
Thanks,
Farhana
Possibly the echo shell command interpret the % its own way. Why don't you generate the SFTP_Script.txt directly from JScript?
You are right about echo command! It does interpret the % in different way! Thanks a lot for your help! :)
