Bug when transferring files to French Freebox
autourdupc
Dear all,
Using WinSCP 4.2.5 on XP Pro SP3, When I try to upload file to the freebox, there is always an error
Error listing directory /xxxx/xxx/
Could not retreive directory listing
Closing data connexion
WHen trying to use IE7 as FTP client, it works fine.
Note that I can't do anything on the Freebox (I do not have any possibility on this server).
Can you please help me ?
Regards,
Laurent (France)
Re: Bug when transferring files to French Freebox
autourdupc
Dear,
The server can't generate log file...
The french freebox is "as this".
It is a box containing a processor. This box permits the ADSL link, the phone connection using VoIP, and to receive TV from Internet and TNT.
It also provides the ability to record TV on an internal hard drive and send to TV video streams coming from the hard drive or external device such as USB hard drives or computers connected on the LAN.
Access to the internal hard drive from the LAN use only FTP, with or without password.
The only way to get a lof report is from the FTP client...
How can I help you ?
Regards,
Laurent (France)
I've asked for log from the WinSCP.
