Error when executing curl command with by gunzip
I am able to connect to a solaris container successfully but im unable to execute the curl command ....
2010-02-02 14:14:12.422 [Shell] curl -q $lv/PATH/cmg.tar.gz?mode=targzdir | gunzip -c | tar -xf - ; echo "WinSCP: this is end-of-file:$?"
! 2010-02-02 14:14:12.843 [Shell] % Total % Received % Xferd Average Speed Time Curr.
! 2010-02-02 14:14:12.843 [Shell] Dload Upload Total Current Left Speed
* 2010-02-02 14:17:35.467 (Exception) Message too long (15913 bytes) to send to external console.
Thanks,
adilno1
Re: Error when executing curl command with by gunzip
Output from your command is too long to be processed by winscp.com. Try using winscp.exe.
