Upload creates a resume subfolder in target directory
Holly Glaser
Seattle
Hello -
I am using Winscp console version 4.0.7.0 and Winscp Gui version 4.2.5
Endurance is set to reconnect automatically each 5 sec for unlimited time
1. The server disconnected and did not reconnect
2. I started the console manually and the upload was resumed and completed loading data to the server.
3. IN the server destination directory, a new subdirectory '-resume' was made
/ebs3/AIS/-resume
If I try to go to the uploaded data in /zip4, the path is not created.
root@domU-12-31-39-00-84-A4:/ebs3/AIS# ls
-resume
root@domU-12-31-39-00-84-A4:/ebs3/AIS# cd "-resume"/zip4
-bash: cd: -r: invalid option
cd: usage: cd [-L|-P] [dir]
Is there a way to avoid this?
Holly Glaser
this is the log file
2010-01-30 12:08:16.989 Opening remote file.
> 2010-01-30 12:08:16.989 Type: SSH_FXP_OPEN, Size: 52, Number: 6147
< 2010-01-30 12:08:17.086 Type: SSH_FXP_HANDLE, Size: 13, Number: 6147
> 2010-01-30 12:08:17.087 Type: SSH_FXP_WRITE, Size: 32764, Number: 6662
. 2010-01-30 12:08:45.039 113 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 12:08:45.039 Type: SSH_FXP_CLOSE, Size: 13, Number: 21252
< 2010-01-30 12:08:45.135 Type: SSH_FXP_STATUS, Size: 24, Number: 21252
< 2010-01-30 12:08:45.135 Status/error code: 0
> 2010-01-30 12:08:45.135 Type: SSH_FXP_REMOVE, Size: 36, Number: 21517
< 2010-01-30 12:08:45.361 Type: SSH_FXP_STATUS, Size: 24, Number: 21517
< 2010-01-30 12:08:45.361 Status/error code: 0
. 2010-01-30 12:08:45.363 Closing connection.
Here the connection failed
Here I restarted the script
. 2010-01-30 14:42:28.293 --------------------------------------------------------------------------
. 2010-01-30 14:42:28.293 WinSCP Version 4.0.7 (Build 370) (OS 6.1.7600)
. 2010-01-30 14:42:28.293 Login time: Saturday, January 30, 2010 2:42:28 PM
. 2010-01-30 14:42:28.293 Session name: OL_ec2B
. 2010-01-30 14:42:28.294 Host name: ec2-72-44-43-178.compute-1.amazonaws.com (Port: 22)
. 2010-01-30 14:42:28.294 User name: root (Password: No, Key file: Yes)
. 2010-01-30 14:42:28.294 Tunnel: No
. 2010-01-30 14:42:28.294 Transfer Protocol: SFTP (SCP)
. 2010-01-30 14:42:28.294 Ping type: N, Ping interval: 15 sec; Timeout: 15 sec
. 2010-01-30 14:42:28.294 Proxy: none
. 2010-01-30 14:42:28.294 SSH protocol version: 2; Compression: No
. 2010-01-30 14:42:28.294 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2010-01-30 14:42:28.294 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2010-01-30 14:42:28.294 SSH Bugs: -,-,-,-,-,-,-,-
. 2010-01-30 14:42:28.295 SFTP Bugs: -,-,-
. 2010-01-30 14:42:28.295 Return code variable: Autodetect; Lookup user groups: Yes
. 2010-01-30 14:42:28.295 Shell: default, EOL: 0
. 2010-01-30 14:42:28.295 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2010-01-30 14:42:28.295 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2010-01-30 14:42:28.295 Local directory: C:\PythonScripts, Remote directory: /ebs3/AIS, Update: Yes, Cache: Yes
. 2010-01-30 14:42:28.295 Cache directory changes: Yes, Permanent: Yes
. 2010-01-30 14:42:28.295 DST mode: 1
. 2010-01-30 14:42:28.295 --------------------------------------------------------------------------
. 2010-01-30 14:42:28.296 Looking up host "ec2-72-44-43-178.compute-1.amazonaws.com"
. 2010-01-30 14:42:28.375 Connecting to 72.44.43.178 port 22
. 2010-01-30 14:42:28.708 Server version: SSH-2.0-OpenSSH_5.1p1 Debian-5ubuntu1
. 2010-01-30 14:42:28.708 We claim version: SSH-2.0-WinSCP_release_4.0.7
. 2010-01-30 14:42:28.708 Using SSH protocol version 2
. 2010-01-30 14:42:28.850 Doing Diffie-Hellman group exchange
. 2010-01-30 14:42:29.166 Doing Diffie-Hellman key exchange
. 2010-01-30 14:42:29.726 Host key fingerprint is:
. 2010-01-30 14:42:29.726 ssh-rsa 2048 ae:f3:e9:3b:32:05:9a:56:01:66:4d:a4:15:b7:ee:fe
. 2010-01-30 14:42:29.727 Initialised AES-256 client->server encryption
. 2010-01-30 14:42:29.727 Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-01-30 14:42:29.727 Initialised AES-256 server->client encryption
. 2010-01-30 14:42:29.727 Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-01-30 14:42:29.919 Using username "root".
. 2010-01-30 14:42:29.920 Reading private key file "C:\terra\amazon_ec2\ec2\oimage.ppk"
. 2010-01-30 14:42:30.019 Offered public key
. 2010-01-30 14:42:30.117 Offer of public key accepted
! 2010-01-30 14:42:30.117 Authenticating with public key "imported-openssh-key"
. 2010-01-30 14:42:31.225 Access granted
. 2010-01-30 14:42:31.321 Opened channel for session
. 2010-01-30 14:42:31.425 Started a shell/command
. 2010-01-30 14:42:31.425 --------------------------------------------------------------------------
. 2010-01-30 14:42:31.425 Using SFTP protocol.
. 2010-01-30 14:42:31.426 Doing startup conversation with host.
> 2010-01-30 14:42:31.426 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2010-01-30 14:42:31.524 Type: SSH_FXP_VERSION, Size: 95, Number: -1
. 2010-01-30 14:42:31.524 SFTP version 3 negotiated.
. 2010-01-30 14:42:31.524 Unknown server extension posix-rename@openssh.com=1
. 2010-01-30 14:42:31.525 Unknown server extension statvfs@openssh.com=2
. 2010-01-30 14:42:31.525 Unknown server extension fstatvfs@openssh.com=2
. 2010-01-30 14:42:31.525 We believe the server has signed timestamps bug
. 2010-01-30 14:42:31.525 We will use UTF-8 strings for status messages only
. 2010-01-30 14:42:31.525 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2010-01-30 14:42:31.525 Changing directory to "/ebs3/AIS".
. 2010-01-30 14:42:31.525 Getting real path for '/ebs3/AIS'
> 2010-01-30 14:42:31.525 Type: SSH_FXP_REALPATH, Size: 18, Number: 16
< 2010-01-30 14:42:31.629 Type: SSH_FXP_NAME, Size: 39, Number: 16
. 2010-01-30 14:42:31.629 Real path is '/ebs3/AIS'
. 2010-01-30 14:42:31.629 Trying to open directory "/ebs3/AIS".
> 2010-01-30 14:42:31.629 Type: SSH_FXP_LSTAT, Size: 18, Number: 263
< 2010-01-30 14:42:31.729 Type: SSH_FXP_ATTRS, Size: 37, Number: 263
. 2010-01-30 14:42:31.730 Getting current directory name.
. 2010-01-30 14:42:31.730 Startup conversation with host finished.
. 2010-01-30 14:42:31.732 Cached directory change via "/ebs3" to "/ebs3".
. 2010-01-30 14:42:31.732 Getting current directory name.
. 2010-01-30 14:42:31.738 [Shell] Looking up host "ec2-72-44-43-178.compute-1.amazonaws.com"
. 2010-01-30 14:42:31.739 [Shell] Connecting to 72.44.43.178 port 22
. 2010-01-30 14:42:31.960 [Shell] Server version: SSH-2.0-OpenSSH_5.1p1 Debian-5ubuntu1
. 2010-01-30 14:42:31.960 [Shell] We claim version: SSH-2.0-WinSCP_release_4.0.7
. 2010-01-30 14:42:31.961 [Shell] Using SSH protocol version 2
. 2010-01-30 14:42:32.059 [Shell] Doing Diffie-Hellman group exchange
. 2010-01-30 14:42:32.340 [Shell] Doing Diffie-Hellman key exchange
. 2010-01-30 14:42:32.823 [Shell] Host key fingerprint is:
. 2010-01-30 14:42:32.824 [Shell] ssh-rsa 2048 ae:f3:e9:3b:32:05:9a:56:01:66:4d:a4:15:b7:ee:fe
. 2010-01-30 14:42:32.824 [Shell] Initialised AES-256 client->server encryption
. 2010-01-30 14:42:32.824 [Shell] Initialised HMAC-SHA1 client->server MAC algorithm
. 2010-01-30 14:42:32.824 [Shell] Initialised AES-256 server->client encryption
. 2010-01-30 14:42:32.824 [Shell] Initialised HMAC-SHA1 server->client MAC algorithm
! 2010-01-30 14:42:33.018 [Shell] Using username "root".
. 2010-01-30 14:42:33.019 [Shell] Reading private key file "C:\terra\amazon_ec2\ec2\oimage.ppk"
. 2010-01-30 14:42:33.143 [Shell] Offered public key
. 2010-01-30 14:42:33.240 [Shell] Offer of public key accepted
! 2010-01-30 14:42:33.240 [Shell] Authenticating with public key "imported-openssh-key"
. 2010-01-30 14:42:34.313 [Shell] Access granted
. 2010-01-30 14:42:34.409 [Shell] Opened channel for session
. 2010-01-30 14:42:34.511 [Shell] Started a shell/command
. 2010-01-30 14:42:34.512 [Shell] --------------------------------------------------------------------------
. 2010-01-30 14:42:34.512 [Shell] Using SCP protocol.
. 2010-01-30 14:42:34.512 [Shell] Doing startup conversation with host.
. 2010-01-30 14:42:34.512 [Shell] Skipping host startup message (if any).
> 2010-01-30 14:42:34.513 [Shell] echo "WinSCP: this is end-of-file:0"
! 2010-01-30 14:42:34.516 [Shell] stdin: is not a tty
< 2010-01-30 14:42:34.713 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:34.713 [Shell] Detecting variable containing return code of last command.
. 2010-01-30 14:42:34.713 [Shell] Trying "$status".
> 2010-01-30 14:42:34.714 [Shell] echo "$status" ; echo "WinSCP: this is end-of-file:0"
< 2010-01-30 14:42:34.944 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:34.944 [Shell] Trying "$?".
> 2010-01-30 14:42:34.945 [Shell] echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 2010-01-30 14:42:35.171 [Shell] 0
< 2010-01-30 14:42:35.171 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:35.172 [Shell] Return code variable "$?" selected.
. 2010-01-30 14:42:35.172 [Shell] Clearing all aliases.
> 2010-01-30 14:42:35.172 [Shell] unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:35.492 [Shell] -bash: line 4: unalias: echo: not found
< 2010-01-30 14:42:35.492 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:35.493 [Shell] unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:35.719 [Shell] -bash: line 5: unalias: pwd: not found
< 2010-01-30 14:42:35.719 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:35.720 [Shell] unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:36.029 [Shell] -bash: line 6: unalias: cd: not found
< 2010-01-30 14:42:36.029 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:36.029 [Shell] unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:36.269 [Shell] -bash: line 7: unalias: ls: not found
< 2010-01-30 14:42:36.270 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:36.270 [Shell] unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:36.502 [Shell] -bash: line 8: unalias: groups: not found
< 2010-01-30 14:42:36.502 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:36.503 [Shell] unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:36.727 [Shell] -bash: line 9: unalias: scp: not found
< 2010-01-30 14:42:36.727 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:36.727 [Shell] unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:37.006 [Shell] -bash: line 10: unalias: rm: not found
< 2010-01-30 14:42:37.006 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:37.007 [Shell] unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:37.313 [Shell] -bash: line 11: unalias: mv: not found
< 2010-01-30 14:42:37.313 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:37.313 [Shell] unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:37.539 [Shell] -bash: line 12: unalias: mkdir: not found
< 2010-01-30 14:42:37.539 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:37.539 [Shell] unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:37.890 [Shell] -bash: line 13: unalias: chmod: not found
< 2010-01-30 14:42:37.890 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:37.890 [Shell] unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:38.085 [Shell] -bash: line 14: unalias: chgrp: not found
< 2010-01-30 14:42:38.086 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:38.086 [Shell] unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:38.323 [Shell] -bash: line 15: unalias: chown: not found
< 2010-01-30 14:42:38.323 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:38.324 [Shell] unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:38.626 [Shell] -bash: line 16: unalias: unset: not found
< 2010-01-30 14:42:38.626 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:38.626 [Shell] unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:38.846 [Shell] -bash: line 17: unalias: unalias: not found
< 2010-01-30 14:42:38.846 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:38.847 [Shell] unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:39.091 [Shell] -bash: line 18: unalias: alias: not found
< 2010-01-30 14:42:39.091 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:39.091 [Shell] unalias "ln" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:39.318 [Shell] -bash: line 19: unalias: ln: not found
< 2010-01-30 14:42:39.319 [Shell] WinSCP: this is end-of-file:1
> 2010-01-30 14:42:39.319 [Shell] unalias "cp" ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:39.555 [Shell] -bash: line 20: unalias: cp: not found
< 2010-01-30 14:42:39.555 [Shell] WinSCP: this is end-of-file:1
. 2010-01-30 14:42:39.555 [Shell] Clearing national user variables.
> 2010-01-30 14:42:39.555 [Shell] unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:39.779 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:39.779 [Shell] unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:40.039 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:40.039 [Shell] unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:40.297 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:40.297 [Shell] unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:40.524 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:40.524 [Shell] unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:40.755 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:40.755 [Shell] unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:40.978 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:40.979 [Shell] unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:41.285 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:41.285 [Shell] unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:41.476 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:41.477 [Shell] unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:41.811 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:41.811 [Shell] unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:42.095 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:42.095 [Shell] Looking up groups and users.
> 2010-01-30 14:42:42.095 [Shell] groups ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:42.330 [Shell] root
< 2010-01-30 14:42:42.331 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:42.331 [Shell] Following groups found:
. 2010-01-30 14:42:42.331 [Shell] root
. 2010-01-30 14:42:42.331 [Shell] No users found.
. 2010-01-30 14:42:42.332 [Shell] Changing directory to "/ebs3".
> 2010-01-30 14:42:42.332 [Shell] cd "/ebs3" ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:42.558 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:42.558 [Shell] Getting current directory name.
> 2010-01-30 14:42:42.559 [Shell] pwd ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:42.780 [Shell] /ebs3
< 2010-01-30 14:42:42.780 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:42.780 [Shell] Startup conversation with host finished.
. 2010-01-30 14:42:42.781 Executing user defined command on command session.
> 2010-01-30 14:42:42.781 [Shell] mkdir -m 777 AIS ; echo "WinSCP: this is end-of-file:$?"
! 2010-01-30 14:42:43.172 [Shell] mkdir: cannot create directory `AIS': File exists
< 2010-01-30 14:42:43.172 [Shell] WinSCP: this is end-of-file:1
* 2010-01-30 14:42:43.173 (ETerminal) Command 'mkdir -m 777 AIS'
* 2010-01-30 14:42:43.173 failed with return code 1 and error message
* 2010-01-30 14:42:43.173 mkdir: cannot create directory `AIS': File exists.
. 2010-01-30 14:42:43.175 Executing user defined command on command session.
> 2010-01-30 14:42:43.175 [Shell] cd AIS ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:43.400 [Shell] WinSCP: this is end-of-file:0
> 2010-01-30 14:42:43.400 [Shell] pwd ; echo "WinSCP: this is end-of-file:$?"
< 2010-01-30 14:42:43.747 [Shell] /ebs3/AIS
< 2010-01-30 14:42:43.747 [Shell] WinSCP: this is end-of-file:0
. 2010-01-30 14:42:43.748 Cached directory change via "/ebs3/AIS" to "/ebs3/AIS".
. 2010-01-30 14:42:43.748 Getting current directory name.
. 2010-01-30 14:42:43.766 Copying 1 files/directories to remote directory "/ebs3/AIS"
. 2010-01-30 14:42:43.766 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: Y (102400); CalcS: No; Mask: -resume
. 2010-01-30 14:42:43.766 TM: A; ClAr: No; ExclM(No):
. 2010-01-30 14:42:43.767 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml, *.py
. 2010-01-30 14:42:43.783 File: "G:\"
. 2010-01-30 14:42:43.800 Trying to open directory "/ebs3/AIS/-resume/".
> 2010-01-30 14:42:43.800 Type: SSH_FXP_LSTAT, Size: 27, Number: 519
< 2010-01-30 14:42:43.895 Type: SSH_FXP_ATTRS, Size: 37, Number: 519
. 2010-01-30 14:42:43.912 File: "G:\crlf"
. 2010-01-30 14:42:43.929 Trying to open directory "/ebs3/AIS/-resume/crlf/".
> 2010-01-30 14:42:43.929 Type: SSH_FXP_LSTAT, Size: 32, Number: 775
< 2010-01-30 14:42:44.026 Type: SSH_FXP_ATTRS, Size: 37, Number: 775
. 2010-01-30 14:42:44.043 File: "G:\crlf\crlf.doc"
. 2010-01-30 14:42:44.094 Copying "G:\crlf\crlf.doc" to remote directory started.
. 2010-01-30 14:42:44.094 Ascii transfer mode selected.
. 2010-01-30 14:42:44.094 Opening remote file.
> 2010-01-30 14:42:44.094 Type: SSH_FXP_OPEN, Size: 56, Number: 1027
< 2010-01-30 14:42:44.244 Type: SSH_FXP_HANDLE, Size: 13, Number: 1027
> 2010-01-30 14:42:44.245 Type: SSH_FXP_WRITE, Size: 4027, Number: 1542
. 2010-01-30 14:42:44.250 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:42:44.250 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
> 2010-01-30 14:42:44.250 Type: SSH_FXP_SETSTAT, Size: 52, Number: 1289
< 2010-01-30 14:42:44.453 Type: SSH_FXP_STATUS, Size: 24, Number: 1542
< 2010-01-30 14:42:44.549 Type: SSH_FXP_STATUS, Size: 24, Number: 1798
< 2010-01-30 14:42:44.576 Type: SSH_FXP_STATUS, Size: 24, Number: 2054
< 2010-01-30 14:42:44.576 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
< 2010-01-30 14:42:44.576 Status/error code: 0
< 2010-01-30 14:42:44.576 Type: SSH_FXP_STATUS, Size: 24, Number: 1289
. 2010-01-30 14:42:44.576 File: "G:\crlf\crlf.exe"
. 2010-01-30 14:42:44.610 Copying "G:\crlf\crlf.exe" to remote directory started.
. 2010-01-30 14:42:44.611 Ascii transfer mode selected.
. 2010-01-30 14:42:44.611 Opening remote file.
> 2010-01-30 14:42:44.611 Type: SSH_FXP_OPEN, Size: 56, Number: 2563
< 2010-01-30 14:42:44.809 Type: SSH_FXP_HANDLE, Size: 13, Number: 2563
> 2010-01-30 14:42:44.809 Type: SSH_FXP_WRITE, Size: 13289, Number: 3078
. 2010-01-30 14:42:45.175 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:42:45.175 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
> 2010-01-30 14:42:45.175 Type: SSH_FXP_SETSTAT, Size: 52, Number: 2825
< 2010-01-30 14:42:45.491 Type: SSH_FXP_STATUS, Size: 24, Number: 3334
< 2010-01-30 14:42:45.824 Type: SSH_FXP_STATUS, Size: 24, Number: 3590
< 2010-01-30 14:42:45.824 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
< 2010-01-30 14:42:45.824 Status/error code: 0
< 2010-01-30 14:42:45.824 Type: SSH_FXP_STATUS, Size: 24, Number: 2825
. 2010-01-30 14:42:45.825 File: "G:\ctystate"
. 2010-01-30 14:42:45.843 Trying to open directory "/ebs3/AIS/-resume/ctystate/".
> 2010-01-30 14:42:45.843 Type: SSH_FXP_LSTAT, Size: 36, Number: 4103
< 2010-01-30 14:42:45.954 Type: SSH_FXP_ATTRS, Size: 37, Number: 4103
. 2010-01-30 14:42:45.970 File: "G:\ctystate\ctystate.zip"
. 2010-01-30 14:42:46.003 Copying "G:\ctystate\ctystate.zip" to remote directory started.
. 2010-01-30 14:42:46.004 Ascii transfer mode selected.
. 2010-01-30 14:42:46.004 Opening remote file.
> 2010-01-30 14:42:46.004 Type: SSH_FXP_OPEN, Size: 64, Number: 4355
< 2010-01-30 14:42:46.214 Type: SSH_FXP_HANDLE, Size: 13, Number: 4355
> 2010-01-30 14:42:46.214 Type: SSH_FXP_WRITE, Size: 28990, Number: 4870
. 2010-01-30 14:44:24.460 390 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:44:24.461 Type: SSH_FXP_CLOSE, Size: 13, Number: 55300
< 2010-01-30 14:44:24.461 Type: SSH_FXP_STATUS, Size: 24, Number: 54534
< 2010-01-30 14:44:24.461 Status/error code: 0
> 2010-01-30 14:44:24.556 Type: SSH_FXP_SETSTAT, Size: 60, Number: 4617
< 2010-01-30 14:44:25.279 Type: SSH_FXP_STATUS, Size: 24, Number: 54790
< 2010-01-30 14:44:25.279 Type: SSH_FXP_STATUS, Size: 24, Number: 55046
< 2010-01-30 14:44:25.377 Type: SSH_FXP_STATUS, Size: 24, Number: 55300
< 2010-01-30 14:44:25.377 Status/error code: 0
< 2010-01-30 14:44:25.377 Type: SSH_FXP_STATUS, Size: 24, Number: 4617
. 2010-01-30 14:44:25.378 File: "G:\layout"
. 2010-01-30 14:44:25.395 Trying to open directory "/ebs3/AIS/-resume/layout/".
> 2010-01-30 14:44:25.395 Type: SSH_FXP_LSTAT, Size: 34, Number: 55559
< 2010-01-30 14:44:25.497 Type: SSH_FXP_ATTRS, Size: 37, Number: 55559
. 2010-01-30 14:44:25.513 File: "G:\layout\ais.pdf"
. 2010-01-30 14:44:25.546 Copying "G:\layout\ais.pdf" to remote directory started.
. 2010-01-30 14:44:25.546 Ascii transfer mode selected.
. 2010-01-30 14:44:25.546 Opening remote file.
> 2010-01-30 14:44:25.546 Type: SSH_FXP_OPEN, Size: 57, Number: 55811
< 2010-01-30 14:44:25.986 Type: SSH_FXP_HANDLE, Size: 13, Number: 55811
> 2010-01-30 14:44:25.987 Type: SSH_FXP_WRITE, Size: 32721, Number: 56326
. 2010-01-30 14:45:55.423 359 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:45:55.424 Type: SSH_FXP_CLOSE, Size: 13, Number: 102660
> 2010-01-30 14:45:55.424 Type: SSH_FXP_SETSTAT, Size: 53, Number: 56073
< 2010-01-30 14:45:55.683 Type: SSH_FXP_STATUS, Size: 24, Number: 102150
< 2010-01-30 14:45:55.919 Type: SSH_FXP_STATUS, Size: 24, Number: 102406
< 2010-01-30 14:45:55.919 Type: SSH_FXP_STATUS, Size: 24, Number: 102660
< 2010-01-30 14:45:55.919 Status/error code: 0
< 2010-01-30 14:45:55.919 Type: SSH_FXP_STATUS, Size: 24, Number: 56073
. 2010-01-30 14:45:55.919 File: "G:\layout\crlf.doc"
. 2010-01-30 14:45:55.953 Copying "G:\layout\crlf.doc" to remote directory started.
. 2010-01-30 14:45:55.953 Ascii transfer mode selected.
. 2010-01-30 14:45:55.953 Opening remote file.
> 2010-01-30 14:45:55.953 Type: SSH_FXP_OPEN, Size: 58, Number: 102915
< 2010-01-30 14:45:56.052 Type: SSH_FXP_HANDLE, Size: 13, Number: 102915
> 2010-01-30 14:45:56.055 Type: SSH_FXP_WRITE, Size: 13861, Number: 103430
> 2010-01-30 14:45:56.059 Type: SSH_FXP_CLOSE, Size: 13, Number: 103684
> 2010-01-30 14:45:56.059 Type: SSH_FXP_SETSTAT, Size: 54, Number: 103177
< 2010-01-30 14:45:56.362 Type: SSH_FXP_STATUS, Size: 24, Number: 103430
< 2010-01-30 14:45:56.362 Type: SSH_FXP_STATUS, Size: 24, Number: 103684
< 2010-01-30 14:45:56.362 Status/error code: 0
< 2010-01-30 14:45:56.362 Type: SSH_FXP_STATUS, Size: 24, Number: 103177
. 2010-01-30 14:45:56.363 File: "G:\layout\ctystate.doc"
. 2010-01-30 14:45:56.396 Copying "G:\layout\ctystate.doc" to remote directory started.
. 2010-01-30 14:45:56.396 Ascii transfer mode selected.
. 2010-01-30 14:45:56.396 Opening remote file.
> 2010-01-30 14:45:56.396 Type: SSH_FXP_OPEN, Size: 62, Number: 103939
< 2010-01-30 14:45:56.492 Type: SSH_FXP_HANDLE, Size: 13, Number: 103939
> 2010-01-30 14:45:56.494 Type: SSH_FXP_WRITE, Size: 10784, Number: 104454
> 2010-01-30 14:45:56.497 Type: SSH_FXP_CLOSE, Size: 13, Number: 104708
> 2010-01-30 14:45:56.498 Type: SSH_FXP_SETSTAT, Size: 58, Number: 104201
< 2010-01-30 14:45:56.727 Type: SSH_FXP_STATUS, Size: 24, Number: 104454
< 2010-01-30 14:45:56.727 Type: SSH_FXP_STATUS, Size: 24, Number: 104708
< 2010-01-30 14:45:56.727 Status/error code: 0
< 2010-01-30 14:45:56.728 Type: SSH_FXP_STATUS, Size: 24, Number: 104201
< 2010-01-30 14:45:56.728 Status/error code: 0
. 2010-01-30 14:45:56.728 File: "G:\layout\readme.doc"
. 2010-01-30 14:45:56.761 Copying "G:\layout\readme.doc" to remote directory started.
. 2010-01-30 14:45:56.761 Ascii transfer mode selected.
. 2010-01-30 14:45:56.761 Opening remote file.
> 2010-01-30 14:45:56.761 Type: SSH_FXP_OPEN, Size: 60, Number: 104963
< 2010-01-30 14:45:56.858 Type: SSH_FXP_HANDLE, Size: 13, Number: 104963
> 2010-01-30 14:45:56.859 Type: SSH_FXP_WRITE, Size: 27161, Number: 105478
> 2010-01-30 14:45:56.864 Type: SSH_FXP_CLOSE, Size: 13, Number: 105732
> 2010-01-30 14:45:56.864 Type: SSH_FXP_SETSTAT, Size: 56, Number: 105225
< 2010-01-30 14:45:57.357 Type: SSH_FXP_STATUS, Size: 24, Number: 105478
< 2010-01-30 14:45:57.357 Type: SSH_FXP_STATUS, Size: 24, Number: 105732
< 2010-01-30 14:45:57.357 Status/error code: 0
< 2010-01-30 14:45:57.358 Type: SSH_FXP_STATUS, Size: 24, Number: 105225
< 2010-01-30 14:45:57.358 Status/error code: 0
. 2010-01-30 14:45:57.358 File: "G:\layout\z4trans.doc"
. 2010-01-30 14:45:57.391 Copying "G:\layout\z4trans.doc" to remote directory started.
. 2010-01-30 14:45:57.391 Ascii transfer mode selected.
. 2010-01-30 14:45:57.391 Opening remote file.
> 2010-01-30 14:45:57.391 Type: SSH_FXP_OPEN, Size: 61, Number: 105987
< 2010-01-30 14:45:57.600 Type: SSH_FXP_HANDLE, Size: 13, Number: 105987
> 2010-01-30 14:45:57.610 Type: SSH_FXP_WRITE, Size: 32365, Number: 106502
. 2010-01-30 14:45:58.316 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:45:58.317 Type: SSH_FXP_CLOSE, Size: 13, Number: 107268
> 2010-01-30 14:45:58.317 Type: SSH_FXP_SETSTAT, Size: 57, Number: 106249
< 2010-01-30 14:45:58.631 Type: SSH_FXP_STATUS, Size: 24, Number: 106758
< 2010-01-30 14:45:58.839 Type: SSH_FXP_STATUS, Size: 24, Number: 107014
< 2010-01-30 14:45:58.839 Type: SSH_FXP_STATUS, Size: 24, Number: 107268
< 2010-01-30 14:45:58.839 Status/error code: 0
< 2010-01-30 14:45:58.839 Type: SSH_FXP_STATUS, Size: 24, Number: 106249
. 2010-01-30 14:45:58.839 File: "G:\layout\zip4.doc"
. 2010-01-30 14:45:58.873 Copying "G:\layout\zip4.doc" to remote directory started.
. 2010-01-30 14:45:58.873 Ascii transfer mode selected.
. 2010-01-30 14:45:58.873 Opening remote file.
> 2010-01-30 14:45:58.873 Type: SSH_FXP_OPEN, Size: 58, Number: 107523
< 2010-01-30 14:45:59.002 Type: SSH_FXP_HANDLE, Size: 13, Number: 107523
> 2010-01-30 14:45:59.013 Type: SSH_FXP_WRITE, Size: 32316, Number: 108038
. 2010-01-30 14:45:59.664 3 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:45:59.664 Type: SSH_FXP_CLOSE, Size: 13, Number: 108804
> 2010-01-30 14:45:59.664 Type: SSH_FXP_SETSTAT, Size: 54, Number: 107785
< 2010-01-30 14:46:00.112 Type: SSH_FXP_STATUS, Size: 24, Number: 108294
< 2010-01-30 14:46:00.453 Type: SSH_FXP_STATUS, Size: 24, Number: 108550
< 2010-01-30 14:46:00.453 Type: SSH_FXP_STATUS, Size: 24, Number: 108804
< 2010-01-30 14:46:00.453 Status/error code: 0
< 2010-01-30 14:46:00.453 Type: SSH_FXP_STATUS, Size: 24, Number: 107785
< 2010-01-30 14:46:00.454 Status/error code: 0
. 2010-01-30 14:46:00.454 File: "G:\z4trans"
. 2010-01-30 14:46:00.471 Trying to open directory "/ebs3/AIS/-resume/z4trans/".
> 2010-01-30 14:46:00.471 Type: SSH_FXP_LSTAT, Size: 35, Number: 109063
< 2010-01-30 14:46:00.569 Type: SSH_FXP_ATTRS, Size: 37, Number: 109063
. 2010-01-30 14:46:00.585 File: "G:\z4trans\006.zip"
. 2010-01-30 14:46:00.619 Copying "G:\z4trans\006.zip" to remote directory started.
. 2010-01-30 14:46:00.619 Ascii transfer mode selected.
. 2010-01-30 14:46:00.620 Opening remote file.
> 2010-01-30 14:46:00.620 Type: SSH_FXP_OPEN, Size: 58, Number: 109315
< 2010-01-30 14:46:00.829 Type: SSH_FXP_HANDLE, Size: 13, Number: 109315
> 2010-01-30 14:46:00.830 Type: SSH_FXP_WRITE, Size: 11021, Number: 109830
> 2010-01-30 14:46:00.833 Type: SSH_FXP_CLOSE, Size: 13, Number: 110084
> 2010-01-30 14:46:00.833 Type: SSH_FXP_SETSTAT, Size: 54, Number: 109577
< 2010-01-30 14:46:01.045 Type: SSH_FXP_STATUS, Size: 24, Number: 109830
< 2010-01-30 14:46:01.046 Type: SSH_FXP_STATUS, Size: 24, Number: 110084
< 2010-01-30 14:46:01.046 Status/error code: 0
< 2010-01-30 14:46:01.046 Type: SSH_FXP_STATUS, Size: 24, Number: 109577
. 2010-01-30 14:46:01.046 File: "G:\z4trans\007.zip"
. 2010-01-30 14:46:01.097 Copying "G:\z4trans\007.zip" to remote directory started.
. 2010-01-30 14:46:01.098 Ascii transfer mode selected.
. 2010-01-30 14:46:01.098 Opening remote file.
> 2010-01-30 14:46:01.098 Type: SSH_FXP_OPEN, Size: 58, Number: 110339
< 2010-01-30 14:46:01.350 Type: SSH_FXP_HANDLE, Size: 13, Number: 110339
> 2010-01-30 14:46:01.351 Type: SSH_FXP_WRITE, Size: 9739, Number: 110854
> 2010-01-30 14:46:01.354 Type: SSH_FXP_CLOSE, Size: 13, Number: 111108
> 2010-01-30 14:46:01.354 Type: SSH_FXP_SETSTAT, Size: 54, Number: 110601
< 2010-01-30 14:46:01.658 Type: SSH_FXP_STATUS, Size: 24, Number: 110854
< 2010-01-30 14:46:01.658 Type: SSH_FXP_STATUS, Size: 24, Number: 111108
< 2010-01-30 14:46:01.658 Status/error code: 0
< 2010-01-30 14:46:01.658 Type: SSH_FXP_STATUS, Size: 24, Number: 110601
< 2010-01-30 14:46:01.659 Status/error code: 0
. 2010-01-30 14:46:01.659 File: "G:\z4trans\008.zip"
. 2010-01-30 14:46:01.692 Copying "G:\z4trans\008.zip" to remote directory started.
. 2010-01-30 14:46:01.693 Ascii transfer mode selected.
. 2010-01-30 14:46:01.693 Opening remote file.
> 2010-01-30 14:46:01.693 Type: SSH_FXP_OPEN, Size: 58, Number: 111363
< 2010-01-30 14:46:01.935 Type: SSH_FXP_HANDLE, Size: 13, Number: 111363
> 2010-01-30 14:46:01.936 Type: SSH_FXP_WRITE, Size: 1782, Number: 111878
> 2010-01-30 14:46:01.937 Type: SSH_FXP_CLOSE, Size: 13, Number: 112132
> 2010-01-30 14:46:01.937 Type: SSH_FXP_SETSTAT, Size: 54, Number: 111625
< 2010-01-30 14:46:02.039 Type: SSH_FXP_STATUS, Size: 24, Number: 111878
< 2010-01-30 14:46:02.135 Type: SSH_FXP_STATUS, Size: 24, Number: 112132
< 2010-01-30 14:46:02.136 Status/error code: 0
< 2010-01-30 14:46:02.136 Type: SSH_FXP_STATUS, Size: 24, Number: 111625
. 2010-01-30 14:46:02.136 File: "G:\z4trans\009.zip"
. 2010-01-30 14:46:02.170 Copying "G:\z4trans\009.zip" to remote directory started.
. 2010-01-30 14:46:02.171 Ascii transfer mode selected.
. 2010-01-30 14:46:02.171 Opening remote file.
> 2010-01-30 14:46:02.171 Type: SSH_FXP_OPEN, Size: 58, Number: 112387
< 2010-01-30 14:46:02.307 Type: SSH_FXP_HANDLE, Size: 13, Number: 112387
> 2010-01-30 14:46:02.308 Type: SSH_FXP_WRITE, Size: 22064, Number: 112902
> 2010-01-30 14:46:02.312 Type: SSH_FXP_CLOSE, Size: 13, Number: 113156
> 2010-01-30 14:46:02.312 Type: SSH_FXP_SETSTAT, Size: 54, Number: 112649
< 2010-01-30 14:46:02.711 Type: SSH_FXP_STATUS, Size: 24, Number: 112902
< 2010-01-30 14:46:02.712 Type: SSH_FXP_STATUS, Size: 24, Number: 113156
< 2010-01-30 14:46:02.712 Status/error code: 0
< 2010-01-30 14:46:02.712 Type: SSH_FXP_STATUS, Size: 24, Number: 112649
. 2010-01-30 14:46:02.712 File: "G:\z4trans\010.zip"
. 2010-01-30 14:46:02.746 Copying "G:\z4trans\010.zip" to remote directory started.
. 2010-01-30 14:46:02.746 Ascii transfer mode selected.
. 2010-01-30 14:46:02.746 Opening remote file.
> 2010-01-30 14:46:02.747 Type: SSH_FXP_OPEN, Size: 58, Number: 113411
< 2010-01-30 14:46:02.844 Type: SSH_FXP_HANDLE, Size: 13, Number: 113411
> 2010-01-30 14:46:02.844 Type: SSH_FXP_WRITE, Size: 12955, Number: 113926
> 2010-01-30 14:46:02.848 Type: SSH_FXP_CLOSE, Size: 13, Number: 114180
> 2010-01-30 14:46:02.848 Type: SSH_FXP_SETSTAT, Size: 54, Number: 113673
< 2010-01-30 14:46:03.168 Type: SSH_FXP_STATUS, Size: 24, Number: 113926
< 2010-01-30 14:46:03.169 Type: SSH_FXP_STATUS, Size: 24, Number: 114180
< 2010-01-30 14:46:03.169 Status/error code: 0
< 2010-01-30 14:46:03.169 Type: SSH_FXP_STATUS, Size: 24, Number: 113673
. 2010-01-30 14:46:03.169 File: "G:\z4trans\011.zip"
. 2010-01-30 14:46:03.203 Copying "G:\z4trans\011.zip" to remote directory started.
. 2010-01-30 14:46:03.203 Ascii transfer mode selected.
. 2010-01-30 14:46:03.203 Opening remote file.
> 2010-01-30 14:46:03.203 Type: SSH_FXP_OPEN, Size: 58, Number: 114435
< 2010-01-30 14:46:03.381 Type: SSH_FXP_HANDLE, Size: 13, Number: 114435
> 2010-01-30 14:46:03.381 Type: SSH_FXP_WRITE, Size: 24834, Number: 114950
> 2010-01-30 14:46:03.386 Type: SSH_FXP_CLOSE, Size: 13, Number: 115204
> 2010-01-30 14:46:03.387 Type: SSH_FXP_SETSTAT, Size: 54, Number: 114697
< 2010-01-30 14:46:03.891 Type: SSH_FXP_STATUS, Size: 24, Number: 114950
< 2010-01-30 14:46:03.891 Type: SSH_FXP_STATUS, Size: 24, Number: 115204
< 2010-01-30 14:46:03.891 Status/error code: 0
< 2010-01-30 14:46:03.891 Type: SSH_FXP_STATUS, Size: 24, Number: 114697
. 2010-01-30 14:46:03.891 File: "G:\z4trans\012.zip"
. 2010-01-30 14:46:03.926 Copying "G:\z4trans\012.zip" to remote directory started.
. 2010-01-30 14:46:03.926 Ascii transfer mode selected.
. 2010-01-30 14:46:03.926 Opening remote file.
> 2010-01-30 14:46:03.926 Type: SSH_FXP_OPEN, Size: 58, Number: 115459
< 2010-01-30 14:46:04.023 Type: SSH_FXP_HANDLE, Size: 13, Number: 115459
> 2010-01-30 14:46:04.024 Type: SSH_FXP_WRITE, Size: 3970, Number: 115974
> 2010-01-30 14:46:04.026 Type: SSH_FXP_CLOSE, Size: 13, Number: 116228
> 2010-01-30 14:46:04.026 Type: SSH_FXP_SETSTAT, Size: 54, Number: 115721
< 2010-01-30 14:46:04.221 Type: SSH_FXP_STATUS, Size: 24, Number: 115974
< 2010-01-30 14:46:04.221 Type: SSH_FXP_STATUS, Size: 24, Number: 116228
< 2010-01-30 14:46:04.221 Status/error code: 0
< 2010-01-30 14:46:04.221 Type: SSH_FXP_STATUS, Size: 24, Number: 115721
. 2010-01-30 14:46:04.221 File: "G:\z4trans\013.zip"
. 2010-01-30 14:46:04.255 Copying "G:\z4trans\013.zip" to remote directory started.
. 2010-01-30 14:46:04.255 Ascii transfer mode selected.
. 2010-01-30 14:46:04.255 Opening remote file.
> 2010-01-30 14:46:04.255 Type: SSH_FXP_OPEN, Size: 58, Number: 116483
< 2010-01-30 14:46:04.351 Type: SSH_FXP_HANDLE, Size: 13, Number: 116483
> 2010-01-30 14:46:04.351 Type: SSH_FXP_WRITE, Size: 681, Number: 116998
> 2010-01-30 14:46:04.352 Type: SSH_FXP_CLOSE, Size: 13, Number: 117252
> 2010-01-30 14:46:04.353 Type: SSH_FXP_SETSTAT, Size: 54, Number: 116745
< 2010-01-30 14:46:04.575 Type: SSH_FXP_STATUS, Size: 24, Number: 116998
< 2010-01-30 14:46:04.576 Type: SSH_FXP_STATUS, Size: 24, Number: 117252
< 2010-01-30 14:46:04.576 Status/error code: 0
< 2010-01-30 14:46:04.576 Type: SSH_FXP_STATUS, Size: 24, Number: 116745
. 2010-01-30 14:46:04.576 File: "G:\z4trans\014.zip"
. 2010-01-30 14:46:04.609 Copying "G:\z4trans\014.zip" to remote directory started.
. 2010-01-30 14:46:04.609 Ascii transfer mode selected.
. 2010-01-30 14:46:04.609 Opening remote file.
> 2010-01-30 14:46:04.609 Type: SSH_FXP_OPEN, Size: 58, Number: 117507
< 2010-01-30 14:46:04.705 Type: SSH_FXP_HANDLE, Size: 13, Number: 117507
> 2010-01-30 14:46:04.706 Type: SSH_FXP_WRITE, Size: 1309, Number: 118022
> 2010-01-30 14:46:04.707 Type: SSH_FXP_CLOSE, Size: 13, Number: 118276
> 2010-01-30 14:46:04.707 Type: SSH_FXP_SETSTAT, Size: 54, Number: 117769
< 2010-01-30 14:46:04.936 Type: SSH_FXP_STATUS, Size: 24, Number: 118022
< 2010-01-30 14:46:04.936 Type: SSH_FXP_STATUS, Size: 24, Number: 118276
< 2010-01-30 14:46:04.936 Status/error code: 0
< 2010-01-30 14:46:04.936 Type: SSH_FXP_STATUS, Size: 24, Number: 117769
. 2010-01-30 14:46:04.937 File: "G:\z4trans\015.zip"
. 2010-01-30 14:46:04.970 Copying "G:\z4trans\015.zip" to remote directory started.
. 2010-01-30 14:46:04.970 Ascii transfer mode selected.
. 2010-01-30 14:46:04.970 Opening remote file.
> 2010-01-30 14:46:04.970 Type: SSH_FXP_OPEN, Size: 58, Number: 118531
< 2010-01-30 14:46:05.068 Type: SSH_FXP_HANDLE, Size: 13, Number: 118531
> 2010-01-30 14:46:05.069 Type: SSH_FXP_WRITE, Size: 30101, Number: 119046
> 2010-01-30 14:46:05.076 Type: SSH_FXP_CLOSE, Size: 13, Number: 119300
> 2010-01-30 14:46:05.076 Type: SSH_FXP_SETSTAT, Size: 54, Number: 118793
< 2010-01-30 14:46:05.625 Type: SSH_FXP_STATUS, Size: 24, Number: 119046
< 2010-01-30 14:46:05.626 Type: SSH_FXP_STATUS, Size: 24, Number: 119300
< 2010-01-30 14:46:05.626 Status/error code: 0
< 2010-01-30 14:46:05.626 Type: SSH_FXP_STATUS, Size: 24, Number: 118793
. 2010-01-30 14:46:05.626 File: "G:\z4trans\016.zip"
. 2010-01-30 14:46:05.660 Copying "G:\z4trans\016.zip" to remote directory started.
. 2010-01-30 14:46:05.660 Ascii transfer mode selected.
. 2010-01-30 14:46:05.660 Opening remote file.
> 2010-01-30 14:46:05.660 Type: SSH_FXP_OPEN, Size: 58, Number: 119555
< 2010-01-30 14:46:05.758 Type: SSH_FXP_HANDLE, Size: 13, Number: 119555
> 2010-01-30 14:46:05.758 Type: SSH_FXP_WRITE, Size: 557, Number: 120070
> 2010-01-30 14:46:05.759 Type: SSH_FXP_CLOSE, Size: 13, Number: 120324
> 2010-01-30 14:46:05.760 Type: SSH_FXP_SETSTAT, Size: 54, Number: 119817
< 2010-01-30 14:46:06.006 Type: SSH_FXP_STATUS, Size: 24, Number: 120070
< 2010-01-30 14:46:06.006 Type: SSH_FXP_STATUS, Size: 24, Number: 120324
< 2010-01-30 14:46:06.006 Status/error code: 0
< 2010-01-30 14:46:06.006 Type: SSH_FXP_STATUS, Size: 24, Number: 119817
< 2010-01-30 14:46:06.007 Status/error code: 0
. 2010-01-30 14:46:06.007 File: "G:\z4trans\017.zip"
. 2010-01-30 14:46:06.040 Copying "G:\z4trans\017.zip" to remote directory started.
. 2010-01-30 14:46:06.040 Ascii transfer mode selected.
. 2010-01-30 14:46:06.040 Opening remote file.
> 2010-01-30 14:46:06.040 Type: SSH_FXP_OPEN, Size: 58, Number: 120579
< 2010-01-30 14:46:06.138 Type: SSH_FXP_HANDLE, Size: 13, Number: 120579
> 2010-01-30 14:46:06.138 Type: SSH_FXP_WRITE, Size: 4277, Number: 121094
> 2010-01-30 14:46:06.140 Type: SSH_FXP_CLOSE, Size: 13, Number: 121348
> 2010-01-30 14:46:06.140 Type: SSH_FXP_SETSTAT, Size: 54, Number: 120841
< 2010-01-30 14:46:06.336 Type: SSH_FXP_STATUS, Size: 24, Number: 121094
< 2010-01-30 14:46:06.336 Type: SSH_FXP_STATUS, Size: 24, Number: 121348
< 2010-01-30 14:46:06.337 Status/error code: 0
< 2010-01-30 14:46:06.337 Type: SSH_FXP_STATUS, Size: 24, Number: 120841
. 2010-01-30 14:46:06.337 File: "G:\z4trans\018.zip"
. 2010-01-30 14:46:06.371 Copying "G:\z4trans\018.zip" to remote directory started.
. 2010-01-30 14:46:06.371 Ascii transfer mode selected.
. 2010-01-30 14:46:06.371 Opening remote file.
> 2010-01-30 14:46:06.372 Type: SSH_FXP_OPEN, Size: 58, Number: 121603
< 2010-01-30 14:46:06.473 Type: SSH_FXP_HANDLE, Size: 13, Number: 121603
> 2010-01-30 14:46:06.474 Type: SSH_FXP_WRITE, Size: 2557, Number: 122118
> 2010-01-30 14:46:06.475 Type: SSH_FXP_CLOSE, Size: 13, Number: 122372
> 2010-01-30 14:46:06.475 Type: SSH_FXP_SETSTAT, Size: 54, Number: 121865
< 2010-01-30 14:46:06.667 Type: SSH_FXP_STATUS, Size: 24, Number: 122118
< 2010-01-30 14:46:06.667 Type: SSH_FXP_STATUS, Size: 24, Number: 122372
< 2010-01-30 14:46:06.668 Status/error code: 0
< 2010-01-30 14:46:06.668 Type: SSH_FXP_STATUS, Size: 24, Number: 121865
. 2010-01-30 14:46:06.668 File: "G:\z4trans\019.zip"
. 2010-01-30 14:46:06.701 Copying "G:\z4trans\019.zip" to remote directory started.
. 2010-01-30 14:46:06.701 Ascii transfer mode selected.
. 2010-01-30 14:46:06.701 Opening remote file.
> 2010-01-30 14:46:06.702 Type: SSH_FXP_OPEN, Size: 58, Number: 122627
< 2010-01-30 14:46:06.797 Type: SSH_FXP_HANDLE, Size: 13, Number: 122627
> 2010-01-30 14:46:06.797 Type: SSH_FXP_WRITE, Size: 2374, Number: 123142
> 2010-01-30 14:46:06.799 Type: SSH_FXP_CLOSE, Size: 13, Number: 123396
> 2010-01-30 14:46:06.799 Type: SSH_FXP_SETSTAT, Size: 54, Number: 122889
< 2010-01-30 14:46:06.991 Type: SSH_FXP_STATUS, Size: 24, Number: 123142
< 2010-01-30 14:46:06.991 Type: SSH_FXP_STATUS, Size: 24, Number: 123396
< 2010-01-30 14:46:06.991 Status/error code: 0
< 2010-01-30 14:46:06.991 Type: SSH_FXP_STATUS, Size: 24, Number: 122889
. 2010-01-30 14:46:06.992 File: "G:\z4trans\020.zip"
. 2010-01-30 14:46:07.025 Copying "G:\z4trans\020.zip" to remote directory started.
. 2010-01-30 14:46:07.025 Ascii transfer mode selected.
. 2010-01-30 14:46:07.026 Opening remote file.
> 2010-01-30 14:46:07.026 Type: SSH_FXP_OPEN, Size: 58, Number: 123651
< 2010-01-30 14:46:07.149 Type: SSH_FXP_HANDLE, Size: 13, Number: 123651
> 2010-01-30 14:46:07.149 Type: SSH_FXP_WRITE, Size: 2893, Number: 124166
> 2010-01-30 14:46:07.151 Type: SSH_FXP_CLOSE, Size: 13, Number: 124420
> 2010-01-30 14:46:07.151 Type: SSH_FXP_SETSTAT, Size: 54, Number: 123913
< 2010-01-30 14:46:07.342 Type: SSH_FXP_STATUS, Size: 24, Number: 124166
< 2010-01-30 14:46:07.342 Type: SSH_FXP_STATUS, Size: 24, Number: 124420
< 2010-01-30 14:46:07.342 Status/error code: 0
< 2010-01-30 14:46:07.343 Type: SSH_FXP_STATUS, Size: 24, Number: 123913
< 2010-01-30 14:46:07.343 Status/error code: 0
. 2010-01-30 14:46:07.343 File: "G:\z4trans\021.zip"
. 2010-01-30 14:46:07.377 Copying "G:\z4trans\021.zip" to remote directory started.
. 2010-01-30 14:46:07.378 Ascii transfer mode selected.
. 2010-01-30 14:46:07.378 Opening remote file.
> 2010-01-30 14:46:07.378 Type: SSH_FXP_OPEN, Size: 58, Number: 124675
< 2010-01-30 14:46:07.478 Type: SSH_FXP_HANDLE, Size: 13, Number: 124675
> 2010-01-30 14:46:07.478 Type: SSH_FXP_WRITE, Size: 10631, Number: 125190
> 2010-01-30 14:46:07.481 Type: SSH_FXP_CLOSE, Size: 13, Number: 125444
> 2010-01-30 14:46:07.481 Type: SSH_FXP_SETSTAT, Size: 54, Number: 124937
< 2010-01-30 14:46:07.681 Type: SSH_FXP_STATUS, Size: 24, Number: 125190
< 2010-01-30 14:46:07.681 Type: SSH_FXP_STATUS, Size: 24, Number: 125444
< 2010-01-30 14:46:07.681 Status/error code: 0
< 2010-01-30 14:46:07.681 Type: SSH_FXP_STATUS, Size: 24, Number: 124937
. 2010-01-30 14:46:07.681 File: "G:\z4trans\022.zip"
. 2010-01-30 14:46:07.714 Copying "G:\z4trans\022.zip" to remote directory started.
. 2010-01-30 14:46:07.714 Ascii transfer mode selected.
. 2010-01-30 14:46:07.715 Opening remote file.
> 2010-01-30 14:46:07.715 Type: SSH_FXP_OPEN, Size: 58, Number: 125699
< 2010-01-30 14:46:07.815 Type: SSH_FXP_HANDLE, Size: 13, Number: 125699
> 2010-01-30 14:46:07.815 Type: SSH_FXP_WRITE, Size: 2044, Number: 126214
> 2010-01-30 14:46:07.817 Type: SSH_FXP_CLOSE, Size: 13, Number: 126468
> 2010-01-30 14:46:07.817 Type: SSH_FXP_SETSTAT, Size: 54, Number: 125961
< 2010-01-30 14:46:08.012 Type: SSH_FXP_STATUS, Size: 24, Number: 126214
< 2010-01-30 14:46:08.012 Type: SSH_FXP_STATUS, Size: 24, Number: 126468
< 2010-01-30 14:46:08.012 Status/error code: 0
< 2010-01-30 14:46:08.012 Type: SSH_FXP_STATUS, Size: 24, Number: 125961
. 2010-01-30 14:46:08.012 File: "G:\z4trans\023.zip"
. 2010-01-30 14:46:08.045 Copying "G:\z4trans\023.zip" to remote directory started.
. 2010-01-30 14:46:08.045 Ascii transfer mode selected.
. 2010-01-30 14:46:08.046 Opening remote file.
> 2010-01-30 14:46:08.046 Type: SSH_FXP_OPEN, Size: 58, Number: 126723
< 2010-01-30 14:46:08.197 Type: SSH_FXP_HANDLE, Size: 13, Number: 126723
> 2010-01-30 14:46:08.198 Type: SSH_FXP_WRITE, Size: 7191, Number: 127238
> 2010-01-30 14:46:08.200 Type: SSH_FXP_CLOSE, Size: 13, Number: 127492
> 2010-01-30 14:46:08.201 Type: SSH_FXP_SETSTAT, Size: 54, Number: 126985
< 2010-01-30 14:46:08.399 Type: SSH_FXP_STATUS, Size: 24, Number: 127238
< 2010-01-30 14:46:08.399 Type: SSH_FXP_STATUS, Size: 24, Number: 127492
< 2010-01-30 14:46:08.399 Status/error code: 0
< 2010-01-30 14:46:08.399 Type: SSH_FXP_STATUS, Size: 24, Number: 126985
. 2010-01-30 14:46:08.399 File: "G:\z4trans\024.zip"
. 2010-01-30 14:46:08.432 Copying "G:\z4trans\024.zip" to remote directory started.
. 2010-01-30 14:46:08.433 Ascii transfer mode selected.
. 2010-01-30 14:46:08.433 Opening remote file.
> 2010-01-30 14:46:08.433 Type: SSH_FXP_OPEN, Size: 58, Number: 127747
< 2010-01-30 14:46:08.532 Type: SSH_FXP_HANDLE, Size: 13, Number: 127747
> 2010-01-30 14:46:08.532 Type: SSH_FXP_WRITE, Size: 2351, Number: 128262
> 2010-01-30 14:46:08.534 Type: SSH_FXP_CLOSE, Size: 13, Number: 128516
> 2010-01-30 14:46:08.534 Type: SSH_FXP_SETSTAT, Size: 54, Number: 128009
< 2010-01-30 14:46:08.727 Type: SSH_FXP_STATUS, Size: 24, Number: 128262
< 2010-01-30 14:46:08.727 Type: SSH_FXP_STATUS, Size: 24, Number: 128516
< 2010-01-30 14:46:08.728 Status/error code: 0
< 2010-01-30 14:46:08.728 Type: SSH_FXP_STATUS, Size: 24, Number: 128009
. 2010-01-30 14:46:08.728 File: "G:\z4trans\025.zip"
. 2010-01-30 14:46:08.761 Copying "G:\z4trans\025.zip" to remote directory started.
. 2010-01-30 14:46:08.762 Ascii transfer mode selected.
. 2010-01-30 14:46:08.762 Opening remote file.
> 2010-01-30 14:46:08.762 Type: SSH_FXP_OPEN, Size: 58, Number: 128771
< 2010-01-30 14:46:08.881 Type: SSH_FXP_HANDLE, Size: 13, Number: 128771
> 2010-01-30 14:46:08.881 Type: SSH_FXP_WRITE, Size: 1336, Number: 129286
> 2010-01-30 14:46:08.883 Type: SSH_FXP_CLOSE, Size: 13, Number: 129540
> 2010-01-30 14:46:08.883 Type: SSH_FXP_SETSTAT, Size: 54, Number: 129033
< 2010-01-30 14:46:09.107 Type: SSH_FXP_STATUS, Size: 24, Number: 129286
< 2010-01-30 14:46:09.107 Type: SSH_FXP_STATUS, Size: 24, Number: 129540
< 2010-01-30 14:46:09.107 Status/error code: 0
< 2010-01-30 14:46:09.108 Type: SSH_FXP_STATUS, Size: 24, Number: 129033
< 2010-01-30 14:46:09.108 Status/error code: 0
. 2010-01-30 14:46:09.108 File: "G:\z4trans\026.zip"
. 2010-01-30 14:46:09.141 Copying "G:\z4trans\026.zip" to remote directory started.
. 2010-01-30 14:46:09.142 Ascii transfer mode selected.
. 2010-01-30 14:46:09.142 Opening remote file.
> 2010-01-30 14:46:09.142 Type: SSH_FXP_OPEN, Size: 58, Number: 129795
< 2010-01-30 14:46:09.241 Type: SSH_FXP_HANDLE, Size: 13, Number: 129795
> 2010-01-30 14:46:09.241 Type: SSH_FXP_WRITE, Size: 1533, Number: 130310
> 2010-01-30 14:46:09.242 Type: SSH_FXP_CLOSE, Size: 13, Number: 130564
> 2010-01-30 14:46:09.243 Type: SSH_FXP_SETSTAT, Size: 54, Number: 130057
< 2010-01-30 14:46:09.472 Type: SSH_FXP_STATUS, Size: 24, Number: 130310
< 2010-01-30 14:46:09.472 Type: SSH_FXP_STATUS, Size: 24, Number: 130564
< 2010-01-30 14:46:09.472 Status/error code: 0
< 2010-01-30 14:46:09.472 Type: SSH_FXP_STATUS, Size: 24, Number: 130057
< 2010-01-30 14:46:09.473 Status/error code: 0
. 2010-01-30 14:46:09.473 File: "G:\z4trans\027.zip"
. 2010-01-30 14:46:09.506 Copying "G:\z4trans\027.zip" to remote directory started.
. 2010-01-30 14:46:09.506 Ascii transfer mode selected.
. 2010-01-30 14:46:09.506 Opening remote file.
> 2010-01-30 14:46:09.506 Type: SSH_FXP_OPEN, Size: 58, Number: 130819
< 2010-01-30 14:46:09.604 Type: SSH_FXP_HANDLE, Size: 13, Number: 130819
> 2010-01-30 14:46:09.604 Type: SSH_FXP_WRITE, Size: 5401, Number: 131334
> 2010-01-30 14:46:09.606 Type: SSH_FXP_CLOSE, Size: 13, Number: 131588
> 2010-01-30 14:46:09.606 Type: SSH_FXP_SETSTAT, Size: 54, Number: 131081
< 2010-01-30 14:46:09.798 Type: SSH_FXP_STATUS, Size: 24, Number: 131334
< 2010-01-30 14:46:09.798 Type: SSH_FXP_STATUS, Size: 24, Number: 131588
< 2010-01-30 14:46:09.798 Status/error code: 0
< 2010-01-30 14:46:09.798 Type: SSH_FXP_STATUS, Size: 24, Number: 131081
. 2010-01-30 14:46:09.799 File: "G:\z4trans\028.zip"
. 2010-01-30 14:46:09.832 Copying "G:\z4trans\028.zip" to remote directory started.
. 2010-01-30 14:46:09.832 Ascii transfer mode selected.
. 2010-01-30 14:46:09.832 Opening remote file.
> 2010-01-30 14:46:09.832 Type: SSH_FXP_OPEN, Size: 58, Number: 131843
< 2010-01-30 14:46:09.958 Type: SSH_FXP_HANDLE, Size: 13, Number: 131843
> 2010-01-30 14:46:09.959 Type: SSH_FXP_WRITE, Size: 21386, Number: 132358
> 2010-01-30 14:46:09.964 Type: SSH_FXP_CLOSE, Size: 13, Number: 132612
> 2010-01-30 14:46:09.964 Type: SSH_FXP_SETSTAT, Size: 54, Number: 132105
< 2010-01-30 14:46:10.409 Type: SSH_FXP_STATUS, Size: 24, Number: 132358
< 2010-01-30 14:46:10.409 Type: SSH_FXP_STATUS, Size: 24, Number: 132612
< 2010-01-30 14:46:10.409 Status/error code: 0
< 2010-01-30 14:46:10.410 Type: SSH_FXP_STATUS, Size: 24, Number: 132105
< 2010-01-30 14:46:10.410 Status/error code: 0
. 2010-01-30 14:46:10.410 File: "G:\z4trans\029.zip"
. 2010-01-30 14:46:10.444 Copying "G:\z4trans\029.zip" to remote directory started.
. 2010-01-30 14:46:10.444 Ascii transfer mode selected.
. 2010-01-30 14:46:10.444 Opening remote file.
> 2010-01-30 14:46:10.444 Type: SSH_FXP_OPEN, Size: 58, Number: 132867
< 2010-01-30 14:46:10.556 Type: SSH_FXP_HANDLE, Size: 13, Number: 132867
> 2010-01-30 14:46:10.556 Type: SSH_FXP_WRITE, Size: 1530, Number: 133382
> 2010-01-30 14:46:10.557 Type: SSH_FXP_CLOSE, Size: 13, Number: 133636
> 2010-01-30 14:46:10.558 Type: SSH_FXP_SETSTAT, Size: 54, Number: 133129
< 2010-01-30 14:46:10.793 Type: SSH_FXP_STATUS, Size: 24, Number: 133382
< 2010-01-30 14:46:10.793 Type: SSH_FXP_STATUS, Size: 24, Number: 133636
< 2010-01-30 14:46:10.793 Status/error code: 0
< 2010-01-30 14:46:10.793 Type: SSH_FXP_STATUS, Size: 24, Number: 133129
< 2010-01-30 14:46:10.794 Status/error code: 0
. 2010-01-30 14:46:10.794 File: "G:\z4trans\030.zip"
. 2010-01-30 14:46:10.827 Copying "G:\z4trans\030.zip" to remote directory started.
. 2010-01-30 14:46:10.827 Ascii transfer mode selected.
. 2010-01-30 14:46:10.827 Opening remote file.
> 2010-01-30 14:46:10.827 Type: SSH_FXP_OPEN, Size: 58, Number: 133891
< 2010-01-30 14:46:10.925 Type: SSH_FXP_HANDLE, Size: 13, Number: 133891
> 2010-01-30 14:46:10.925 Type: SSH_FXP_WRITE, Size: 2228, Number: 134406
> 2010-01-30 14:46:10.927 Type: SSH_FXP_CLOSE, Size: 13, Number: 134660
> 2010-01-30 14:46:10.927 Type: SSH_FXP_SETSTAT, Size: 54, Number: 134153
< 2010-01-30 14:46:11.143 Type: SSH_FXP_STATUS, Size: 24, Number: 134406
< 2010-01-30 14:46:11.144 Type: SSH_FXP_STATUS, Size: 24, Number: 134660
< 2010-01-30 14:46:11.144 Status/error code: 0
< 2010-01-30 14:46:11.144 Type: SSH_FXP_STATUS, Size: 24, Number: 134153
. 2010-01-30 14:46:11.144 File: "G:\z4trans\031.zip"
. 2010-01-30 14:46:11.177 Copying "G:\z4trans\031.zip" to remote directory started.
. 2010-01-30 14:46:11.177 Ascii transfer mode selected.
. 2010-01-30 14:46:11.177 Opening remote file.
> 2010-01-30 14:46:11.177 Type: SSH_FXP_OPEN, Size: 58, Number: 134915
< 2010-01-30 14:46:11.300 Type: SSH_FXP_HANDLE, Size: 13, Number: 134915
> 2010-01-30 14:46:11.301 Type: SSH_FXP_WRITE, Size: 32764, Number: 135430
. 2010-01-30 14:46:11.500 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2010-01-30 14:46:11.501 Type: SSH_FXP_CLOSE, Size: 13, Number: 135940
> 2010-01-30 14:46:11.501 Type: SSH_FXP_SETSTAT, Size: 54, Number: 135177
< 2010-01-30 14:46:11.813 Type: SSH_FXP_STATUS, Size: 24, Number: 135430
< 2010-01-30 14:46:12.158 Type: SSH_FXP_STATUS, Size: 24, Number: 135686
< 2010-01-30 14:46:12.158 Type: SSH_FXP_STATUS, Size: 24, Number: 135940
< 2010-01-30 14:46:12.158 Status/error code: 0
< 2010-01-30 14:46:12.158 Type: SSH_FXP_STATUS, Size: 24, Number: 135177
< 2010-01-30 14:46:12.159 Status/error code: 0
. 2010-01-30 14:46:12.159 File: "G:\z4trans\032.zip"
. 2010-01-30 14:46:12.192 Copying "G:\z4trans\032.zip" to remote directory started.
. 2010-01-30 14:46:12.192 Ascii transfer mode selected.
. 2010-01-30 14:46:12.192 Opening remote file.
> 2010-01-30 14:46:12.192 Type: SSH_FXP_OPEN, Size: 58, Number: 136195
< 2010-01-30 14:46:12.290 Type: SSH_FXP_HANDLE, Size: 13, Number: 136195
> 2010-01-30 14:46:12.290 Type: SSH_FXP_WRITE, Size: 2886, Number: 136710
> 2010-01-30 14:46:12.292 Type: SSH_FXP_CLOSE, Size: 13, Number: 136964
> 2010-01-30 14:46:12.292 Type: SSH_FXP_SETSTAT, Size: 54, Number: 136457
< 2010-01-30 14:46:12.484 Type: SSH_FXP_STATUS, Size: 24, Number: 136710
< 2010-01-30 14:46:12.485 Type: SSH_FXP_STATUS, Size: 24, Number: 136964
< 2010-01-30 14:46:12.485 Status/error code: 0
< 2010-01-30 14:46:12.485 Type: SSH_FXP_STATUS, Size: 24, Number: 136457
. 2010-01-30 14:46:12.485 File: "G:\z4trans\033.zip"
. 2010-01-30 14:46:12.518 Copying "G:\z4trans\033.zip" to remote directory started.
. 2010-01-30 14:46:12.518 Ascii transfer mode selected.
. 2010-01-30 14:46:12.518 Opening remote file.
> 2010-01-30 14:46:12.518 Type: SSH_FXP_OPEN, Size: 58, Number: 137219
< 2010-01-30 14:46:12.616 Type: SSH_FXP_HANDLE, Size: 13, Number: 137219
> 2010-01-30 14:46:12.616 Type: SSH_FXP_WRITE, Size: 845, Number: 137734
> 2010-01-30 14:46:12.617 Type: SSH_FXP_CLOSE, Size: 13, Number: 137988
> 2010-01-30 14:46:12.617 Type: SSH_FXP_SETSTAT, Size: 54, Number: 137481
< 2010-01-30 14:46:12.870 Type: SSH_FXP_STATUS, Size: 24, Number: 137734
< 2010-01-30 14:46:12.871 Type: SSH_FXP_STATUS, Size: 24, Number: 137988
< 2010-01-30 14:46:12.871 Status/error code: 0
< 2010-01-30 14:46:12.871 Type: SSH_FXP_STATUS, Size: 24, Number: 137481
. 2010-01-30 14:46:12.871 File: "G:\z4trans\034.zip"
. 2010-01-30 14:46:12.904 Copying "G:\z4trans\034.zip" to remote directory started.
. 2010-01-30 14:46:12.904 Ascii transfer mode selected.
. 2010-01-30 14:46:12.905 Opening remote file.
> 2010-01-30 14:46:12.905 Type: SSH_FXP_OPEN, Size: 58, Number: 138243
< 2010-01-30 14:46:13.002 Type: SSH_FXP_HANDLE, Size: 13, Number: 138243
> 2010-01-30 14:46:13.003 Type: SSH_FXP_WRITE, Size: 1355, Number: 138758
> 2010-01-30 14:46:13.004 Type: SSH_FXP_CLOSE, Size: 13, Number: 139012
> 2010-01-30 14:46:13.004 Type: SSH_FXP_SETSTAT, Size: 54, Number: 138505
< 2010-01-30 14:46:13.261 Type: SSH_FXP_STATUS, Size: 24, Number: 138758
< 2010-01-30 14:46:13.261 Type: SSH_FXP_STATUS, Size: 24, Number: 139012
< 2010-01-30 14:46:13.261 Status/error code: 0
< 2010-01-30 14:46:13.261 Type: SSH_FXP_STATUS, Size: 24, Number: 138505
< 2010-01-30 14:46:13.262 Status/error code: 0
. 2010-01-30 14:46:13.262 File: "G:\z4trans\035.zip"
. 2010-01-30 14:46:13.381 Copying "G:\z4trans\035.zip" to remote directory started.
. 2010-01-30 14:46:13.381 Ascii transfer mode selected.
. 2010-01-30 14:46:13.382 Opening remote file.
> 2010-01-30 14:46:13.382 Type: SSH_FXP_OPEN, Size: 58, Number: 139267
< 2010-01-30 14:46:13.479 Type: SSH_FXP_HANDLE, Size: 13, Number: 139267
> 2010-01-30 14:46:13.479 Type: SSH_FXP_WRITE, Size: 1096, Number: 139782
> 2010-01-30 14:46:13.480 Type: SSH_FXP_CLOSE, Size: 13, Number: 140036
> 2010-01-30 14:46:13.480 Type: SSH_FXP_SETSTAT, Size: 54, Number: 139529
< 2010-01-30 14:46:13.711 Type: SSH_FXP_STATUS, Size: 24, Number: 139782
< 2010-01-30 14:46:13.711 Type: SSH_FXP_STATUS, Size: 24, Number: 140036
< 2010-01-30 14:46:13.711 Status/error code: 0
< 2010-01-30 14:46:13.711 Type: SSH_FXP_STATUS, Size: 24, Number: 139529
< 2010-01-30 14:46:13.712 Status/error code: 0
. 2010-01-30 14:46:13.712 File: "G:\z4trans\037.zip"
. 2010-01-30 14:46:13.745 Copying "G:\z4trans\037.zip" to remote directory started.
. 2010-01-30 14:46:13.745 Ascii transfer mode selected.
. 2010-01-30 14:46:13.745 Opening remote file.
> 2010-01-30 14:46:13.746 Type: SSH_FXP_OPEN, Size: 58, Number: 140291
< 2010-01-30 14:46:13.842 Type: SSH_FXP_HANDLE, Size: 13, Number: 140291
> 2010-01-30 14:46:13.842 Type: SSH_FXP_WRITE, Size: 2327, Number: 140806
> 2010-01-30 14:46:13.844 Type: SSH_FXP_CLOSE, Size: 13, Number: 141060
> 2010-01-30 14:46:13.844 Type: SSH_FXP_SETSTAT, Size: 54, Number: 140553
< 2010-01-30 14:46:14.068 Type: SSH_FXP_STATUS, Size: 24, Number: 140806
< 2010-01-30 14:46:14.068 Type: SSH_FXP_STATUS, Size: 24, Number: 141060
< 2010-01-30 14:46:14.068 Status/error code: 0
< 2010-01-30 14:46:14.068 Type: SSH_FXP_STATUS, Size: 24, Number: 140553
. 2010-01-30 14:46:14.068 File: "G:\z4trans\038.zip"
. 2010-01-30 14:46:14.101 Copying "G:\z4trans\038.zip" to remote directory started.
. 2010-01-30 14:46:14.101 Ascii transfer mode selected.
. 2010-01-30 14:46:14.102 Opening remote file.
> 2010-01-30 14:46:14.102 Type: SSH_FXP_OPEN, Size: 58, Number: 141315
< 2010-01-30 14:46:14.199 Type: SSH_FXP_HANDLE, Size: 13, Number: 141315
> 2010-01-30 14:46:14.199 Type: SSH_FXP_WRITE, Size: 18512, Number: 141830
> 2010-01-30 14:46:14.204 Type: SSH_FXP_CLOSE, Size: 13, Number: 142084
> 2010-01-30 14:46:14.204 Type: SSH_FXP_SETSTAT, Size: 54, Number: 141577
< 2010-01-30 14:46:14.506 Type: SSH_FXP_STATUS, Size: 24, Number: 141830
< 2010-01-30 14:46:14.507 Type: SSH_FXP_STATUS, Size: 24, Number: 142084
< 2010-01-30 14:46:14.507 Status/error code: 0
< 2010-01-30 14:46:14.507 Type: SSH_FXP_STATUS, Size: 24, Number: 141577
. 2010-01-30 14:46:14.507 File: "G:\z4trans\039.zip"
. 2010-01-30 14:46:14.540 Copying "G:\z4trans\039.zip" to remote directory started.
. 2010-01-30 14:46:14.540 Ascii transfer mode selected.
. 2010-01-30 14:46:14.541 Opening remote file.
> 2010-01-30 14:46:14.541 Type: SSH_FXP_OPEN, Size: 58, Number: 142339
< 2010-01-30 14:46:14.702 Type: SSH_FXP_HANDLE, Size: 13, Number: 142339
> 2010-01-30 14:46:14.703 Type: SSH_FXP_WRITE, Size: 889, Number: 142854
> 2010-01-30 14:46:14.704 Type: SSH_FXP_CLOSE, Size: 13, Number: 143108
> 2010-01-30 14:46:14.704 Type: SSH_FXP_SETSTAT, Size: 54, Number: 142601
< 2010-01-30 14:46:14.898 Type: SSH_FXP_STATUS, Size: 24, Number: 142854
< 2010-01-30 14:46:14.898 Type: SSH_FXP_STATUS, Size: 24, Number: 143108
< 2010-01-30 14:46:14.898 Status/error code: 0
< 2010-01-30 14:46:14.898 Type: SSH_FXP_STATUS, Size: 24, Number: 142601
. 2010-01-30 14:46:14.898 File: "G:\z4trans\040.zip"
. 2010-01-30 14:46:14.931 Copying "G:\z4trans\040.zip" to remote directory started.
. 2010-01-30 14:46:14.931 Ascii transfer mode selected.
. 2010-01-30 14:46:14.932 Opening remote file.
> 2010-01-30 14:46:14.932 Type: SSH_FXP_OPEN, Size: 58, Number: 143363
< 2010-01-30 14:46:15.160 Type: SSH_FXP_HANDLE, Size: 13, Number: 143363
> 2010-01-30 14:46:15.160 Type: SSH_FXP_WRITE, Size: 3793, Number: 143878
> 2010-01-30 14:46:15.162 Type: SSH_FXP_CLOSE, Size: 13, Number: 144132
> 2010-01-30 14:46:15.162 Type: SSH_FXP_SETSTAT, Size: 54, Number: 143625
< 2010-01-30 14:46:15.391 Type: SSH_FXP_STATUS, Size: 24, Number: 143878
< 2010-01-30 14:46:15.391 Type: SSH_FXP_STATUS, Size: 24, Number: 144132
< 2010-01-30 14:46:15.391 Status/error code: 0
< 2010-01-30 14:46:15.391 Type: SSH_FXP_STATUS, Size: 24, Number: 143625
. 2010-01-30 14:46:15.391 File: "G:\z4trans\041.zip"
. 2010-01-30 14:46:15.511 Copying "G:\z4trans\041.zip" to remote directory started.
. 2010-01-30 14:46:15.512 Ascii transfer mode selected.
. 2010-01-30 14:46:15.512 Opening remote file.
> 2010-01-30 14:46:15.512 Type: SSH_FXP_OPEN, Size: 58, Number: 144387
< 2010-01-30 14:46:15.607 Type: SSH_FXP_HANDLE, Size: 13, Number: 144387
> 2010-01-30 14:46:15.608 Type: SSH_FXP_WRITE, Size: 4098, Number: 144902
> 2010-01-30 14:46:15.610 Type: SSH_FXP_CLOSE, Size: 13, Number: 145156
> 2010-01-30 14:46:15.610 Type: SSH_FXP_SETSTAT, Size: 54, Number: 144649
< 2010-01-30 14:46:15.802 Type: SSH_FXP_STATUS, Size: 24, Number: 144902
< 2010-01-30 14:46:15.802 Type: SSH_FXP_STATUS, Size: 24, Number: 145156
< 2010-01-30 14:46:15.803 Status/error code: 0
< 2010-01-30 14:46:15.803 Type: SSH_FXP_STATUS, Size: 24, Number: 144649
. 2010-01-30 14:46:15.803 File: "G:\z4trans\042.zip"
. 2010-01-30 14:46:15.836 Copying "G:\z4trans\042.zip" to remote directory started.
. 2010-01-30 14:46:15.837 Ascii transfer mode selected.
. 2010-01-30 14:46:15.837 Opening remote file.
> 2010-01-30 14:46:15.837 Type: SSH_FXP_OPEN, Size: 58, Number: 145411
< 2010-01-30 14:46:15.933 Type: SSH_FXP_HANDLE, Size: 13, Number: 145411
> 2010-01-30 14:46:15.934 Type: SSH_FXP_WRITE, Size: 3547, Number: 145926
> 2010-01-30 14:46:15.936 Type: SSH_FXP_CLOSE, Size: 13, Number: 146180
> 2010-01-30 14:46:15.936 Type: SSH_FXP_SETSTAT, Size: 54, Number: 145673
< 2010-01-30 14:46:16.156 Type: SSH_FXP_STATUS, Size: 24, Number: 145926
< 2010-01-30 14:46:16.157 Type: SSH_FXP_STATUS, Size: 24, Number: 146180
< 2010-01-30 14:46:16.157 Status/error code: 0
< 2010-01-30 14:46:16.157 Type: SSH_FXP_STATUS, Size: 24, Number: 145673
Re: Upload creates a resume subfolder in target directory
WinSCP 4.0.7 does not support any switches for script commands. So it treats -resume as a filename. You need to upgrade.
