Moving files
gramirez
Moving files
Hi everybody :P
Is there a way to move files between folders on remote side ?
Whay when I move files from local to remote some files are not deleted from local side ?
Thank you
Re: Moving files
Currently, it is possible only with SCP protocol using custom commands. There is predefined command "Move".
If you have such suspicion, I would appreciate more information.
