WinSCP Won't show C:\ Drives content
Rocket442
NY
For some reason, just in the past couple days my WinSCP installation won't show any of my files/folders in the C:\ Drive of my computer. Every other Drive still works, and I'm stumped as to what to do to fix it
I tried updating after it happened and did, but that didn't change anything either. I recently installed InstantRails (A ruby on rails dev environment but I don't see how that'd affect this, nothing else has even changed with the computer)
I'm on Windows 7 and WinSCP 4.2.5 Build 624
Thanks in advance for any help at all.
Rocket442
NY
Whenever I'm in any directory within the C Drive, it just shows nothing in the view area. Its not loading or freezing.
When I click on the darker blue area with the path I'm in currently and try to load anything from there that is int he C Drive I get this message:
"C:\ is not accessible
Access Denied"
chelseaisa
so any solutions around this?
I encountered this problem with my drive d... you may try to right click then choose explore to view your drive c's contents
guest
same problem
OS: Windows 7 Home Premium X64
To see a disk - me it is necessary to start WinSCP on behalf of the Administrator that involves weight of difficulties.
Re: same problem
So does you account have an access to C:\? Or do you need to elevate your priviledges before?
guest
Yes. My account have an access to C:\
I have only one HDD partition C:\ and the only one account. All other programmes such as Total Commander, Explorer, FireFox and so on can perfectly see and work with drive C:\
2 months ago I had 3 partitions C,D,E and everything worked fine. Maybe this information will be usefull.
guest
OK, am I still talking to Rocket442? I'm going to send you a debug version.
No :) Guest is Sergey
my e-mail: sergei999{*}inbox.ru
I'd like to recieve improved version too :)
selmoatse
I'm running Windows 7 and have the same problem as the OP. For some reason WinSCP can no longer browse the C drive without administrator privileges. I've also noticed that bsnes has the same issue. However, Microsoft Word and all other programs I've tested work fine.
I've noticed that the programs that can't read the contents of the C drive are those not using the standard "open file" dialog box (libraries pane on the left, etc).
selmoatse
I forgot to mention: when I click the button allowing me to browse for my public key file, an XP-style "open file" dialog box appears and can browse the C drive just fine. However it doesn't work in commander mode or after double clicking on the C drive.
Maybe the programs that do not work are 32 bit, while those that work are 64 bit?
Hinano
Same problem here
I'm also experiencing this problem (win7). I even uninstalled and downgraded to 4.2.6 but the problem persists although it never happened before. I saw only one system update from Microsoft over the weekend and it was a virus definition update so I don't think it was that. I'm running 32bit if that helps. Thanks for the help.
stefan6667
same problem here
Same problem as described by @Rocket442, I'm running Windows 7 64-Bit and WinSCP Version 4.2.7 (Build 758).
I just did a fresh install of W7 a few days ago, I was running WinSCP (an older version) on Vista 64 before without problems for years.
drbawb
MKE
I am also having this issue on Windows 7 x64.
If I run the program as administrator, I do not get the access denied message.
(I even marked myself as owner of C:\, and I know I am owner of my users directory, and still it refuses to let me view any part of C:\)
@ForSpud: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
AKX
Finland
The same thing started happening to me today. The left pane for C:\ is blank, and hitting Browse in the Open Directory dialog gets me a Windows "C:\ is not accessible. Access is denied." error message, before opening the Windows directory browser dialog... wherein I'm unable to expand the C:\ branch, of course.
It's not limited to only WinSCP though - Komodo Edit (32-bit) is doing it too in any and all file dialogs.
However, a 32-bit Notepad (C:\Windows\SysWoW64\Notepad.exe) doesn't have this problem; I can browse C:\ as much as I want.
dafeder
same problem
Just upgraded to latest version and having the same problem. Can access all these dirs fine through windows explorer.
arckex
install
I'm in Windows 7 (running 32-bit, tho i have a 64-bit CPU), and I can't even install WinSCP while trying to "Run as Admin". I thought maybe it was just a current version thing, but it I couldn't get ANY version of WinSCP to install, even while using administrative rights (only tried Versions 3+).
Current versions give me a language selector, and then immediately throw me an ambiguous "Access Is Denied" error. Older version let me choose a few more options before giving me similar denial messages.
I've never encountered a problem like this with any other program, and I've been running Windows 7 for months.
arckex
more info
After some further finagling, i was able to get WinSCP 3 to install to a directory located outside of "Program Files". (I made sure I used Admin rights for EVERYTHING i did). So, there must be some sort of failed permissions check happening here.
Re: install
@arckex: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Hilarion
Hilarion avatar
Kraków, Poland
Re: WinSCP Won't show C:\ Drives content
This may be caused by User Account Control (UAC) function.
If WinSCP works OK when used "run as admin" option and user is not required to enter credentials (login/password), then it means that the access was blocked by UAC feature connected with new access rights set for system drive. Windows 7 uses different initial access rights settings for system drive than previous Windows versions. This means that one has to have administrative rights to save files directly on system drive and those rights are by default stripped by UAC (and are "given back" when program is "run as admin").
I'm not sure why would it prevent reading root folder contents, but I suspect that UAC and ACL has something to do with it too (maybe WinSCP is trying to use more privileges than simple read/list).
I'll try to post Windows 7 system drive ACL settings when I'm at my Windows 7 box. Maybe that'll help to resolve the issue.
Hilarion
Hilarion avatar
Kraków, Poland
It looks like I was right about ACL. The root folder of system drive restricts some rights to non-administrative users. One can create new folders there and fully access subfolders, but creating and/or modifying files directly in the root folder is for admins only.
When I say admins only I also mean administrative users when UAC is active (application accessing the files was run normally - without privilege elevation).
This may be the cause of errors if WinSCP is trying to create files or access existing files in read-write mode, when navigated to root folder.
@Hilarion: Thanks for your investigation. Though I still do not understand how this could block reading of directory content. Directory AFAIK cannot be opened in read/write mode (in other words, there's no write mode for directory).
allycat815@...
Solution!!
I had the same problem, all you have to do is go to the Local tab, then click Go To, and then Open Directory/Bookmark and where the address says C:/Users/YourName/Desktop or whatever just delete it until it just says C:/ and you're all set :)
howarddavidp@...
I have another work around...
I went into the WinSCP options, and you can add WinSCP to the Explorer menu items, so that you can right click a file and do a SEND-TO WinSCP host as upload.
this worked for me, I was able to upload using this.
Shame about not being able to browse any longer... I was able to 3 months ago...
David
sai56
It got worked
Go to Preferences in WinSCP --> Interfaces --> Select "Commander" in User Interface --> click Ok
Then close the WinSCP and open it then we can see the C: Drive content
7-twenty
I see an earlier string of users on Windows 7 having issues seeing the contents of their C:\ drives subject "WinSCP Won't show C:\ Drives content". As of today, I am experiencing the same issue on Windows 10 using the latest version of WinSCP, Version 5.17.5 (Build 10414). Please advise. Thank you.
@7-twenty: Thanks for your report. Please start a new thread and post more details. Is it only C: root? Or a whole drive? Do you get any error? Some screenshot may help too.
Re: Can't enter to local drives
@guest2020corona: The same, please start a new thread and provide a way more information. I do not understand what does it mean "Can't enter to local drives." Some screenshots might help too.
