What Determines the Order of Custom Commands in the Toolbar?
purefusion
Happyworld Land
What determines the order of commands in the Custom Commands toolbar?
They seem to change in a very odd fashion. If I use command X, it might reorder itself to be first. If I then use command Y, instead of reordering itself to be first, it reorders itself to be second.
Also, when I restart, the order is never maintained. It always reverts so some odd order, and that order is never the order specified in the preferences (as is the case for the context-menu listing of custom commands).
Very quirky. I think it should be fixed.
Re: What Determines the Order of Custom Commands in the Toolbar?
For me the buttons are ordered exactly the same way as in the preferences. If you see something different, please post a screenshot (showing the toolbar with preferences dialog next to it).
