problem running as windows xp limited user
nhavens
Connecting to a linux ssh server as an administrative windows user succeeds every time. Connecting to the same server as a limited windows user succeeds at best half the times attempted. When a failure happens, I see the prompt for session information. I put in the server, username, and password. The message box comes up saying that it is connecting. It disappears and no file browser window comes up, though the task manager indicates that a winscp process is still running.
Using Windows XP SP3 with WinSCP 4.25 installed or portable executable and SFTP protocol. Same issue connecting to Ubuntu 9.10 desktop or server running openssh-server package version 1:5.1p1-6ubuntu2, RHEL 5.2 running openssh-server-4.3p2-26.el5_2.1
No issues connecting with putty as a limited windows user.
Log from successful connection (as limited user):
> 2010-01-27 14:55:29.781 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
> 2010-01-27 14:55:29.781 04,00,00,08,04,00,00,00,04,00,00,00,00,
. 2010-01-27 14:55:29.781 Sent 17 bytes
. 2010-01-27 14:55:29.781 There are 0 bytes remaining in the send buffer
. 2010-01-27 14:55:29.781 Looking for network events
. 2010-01-27 14:55:29.781 Detected network event
. 2010-01-27 14:55:29.781 Enumerating network events for socket 688
. 2010-01-27 14:55:29.781 Enumerated 1 network events making 1 cumulative events for socket 688
. 2010-01-27 14:55:29.781 Handling network read event on socket 688 with error 0
. 2010-01-27 14:55:29.781 Received 28 bytes (0)
. 2010-01-27 14:55:29.781 Startup conversation with host finished.
. 2010-01-27 14:55:31.984 Session upkeep
. 2010-01-27 14:55:31.984 Looking for network events
. 2010-01-27 14:55:31.984 Detected network event
. 2010-01-27 14:55:31.984 Enumerating network events for socket 688
. 2010-01-27 14:55:31.984 Enumerated 0 network events making 0 cumulative events for socket 688
. 2010-01-27 14:55:32.453 Session upkeep
. 2010-01-27 14:55:32.468 Looking for network events
. 2010-01-27 14:55:32.468 Timeout waiting for network events
. 2010-01-27 14:55:32.953 Session upkeep
Log from unsuccessful connection (as limited user):
. 2010-01-27 15:44:12.171 Read file '.xsession-errors.old' from listing
< 2010-01-27 15:44:12.171 Status code: 1
> 2010-01-27 15:44:12.171 Type: SSH_FXP_CLOSE, Size: 13, Number: 2052
> 2010-01-27 15:44:12.171 04,00,00,08,04,00,00,00,04,00,00,00,00,
. 2010-01-27 15:44:12.171 Sent 17 bytes
. 2010-01-27 15:44:12.171 There are 0 bytes remaining in the send buffer
. 2010-01-27 15:44:12.171 Looking for network events
. 2010-01-27 15:44:12.171 Timeout waiting for network events
. 2010-01-27 15:44:12.171 Startup conversation with host finished.
Re: problem running as windows xp limited user
nhavens
I have sent you the e-mail you requested.
nhavens
I cannot reproduce the problem with your debug version of WinSCP (version 4.26, build 649). What is the difference between the debug version and WinSCP 4.25 (build 624)? When will version 4.26 be available for download in a non-debugging form?
