Issue with passing command line parameter (path) with space
Carmageddon
Israel
Hi, I am developing tools for our company's server farm monitoring - to ease the job of the operators.
One of the things we need to do sometimes, is retrieve the certain event logs from servers.
So far people would use WinSCP manually.
I am trying to get them now automatically via JavaScript with just single click from web status monitoring page, something like this:
winscp.exe /ini=C:\WinSCP.ini" SessionName1 /console /command "cd /home/username1/logs/uut/MN00093\IVT Gen2" "get event* c:\tmp"
Then, in the command line window, I get something like:
Too many parameters for the command 'cd'.
And of course, then it would (or would not..) copy entirely different files since it didn't change to the folder with space in it...
I have tried everything I could think of... I tried doing \ to escape the space, I tried the web standard of %20 - nothing works.
WinSCP version is 4.1.8 build 415.
Is there a workaround to this? if not this really needs some fix please.. asap :)
Also - one more question please: how do I specify actions other than the /defaults parameter? so I can customize the actions via the command line parameters too :)
Thanks!
Re: Issue with passing command line parameter (path) with space
Please read documentation. If that does not help, come back.
I do not understand. Give me an example of what you are trying to do.
Carmageddon
Israel
From the documentation:
Command parameters that include space(s) have to be enclosed in double-quotes....
put "file with spaces and ""quotes"".html"
However, this is good for running a static SCRIPT file, not for when I try to use command line parameters using the /command parameter to RUN the application in /console mode.
I however went ahead and tried out like in the instructions example (note the extra quotes for the path inside cd command):
winscp.exe /ini=C:\WinSCP.ini" SessionName1 /console /command "cd "/home/username1/logs/uut/MN00093\IVT Gen2"" "get event* c:\tmp"
I get this error in the running console:
Error changing directory to '/home/username1/logs/uut/MN00093\IVT'.
Cannot get real path for '/home/username1/logs/uut/MN00093\IVT'.
So, seems there is nothing documented for spaces passed inside a PARAMETER to the application(not in a script!).
Any other suggestions?
Regarding the bit about /defaults – what I mean is, if I for example use /synchronize parameter - if I don't specify the /default parameter, its gonna ask the user, whether I want to port to local, remote, which files to overwrite etc.
Is there a way to specify all these options manually in command line parameters? other than /defaults?
I hope now you understand, what I am trying to accomplish :)
It is the same:
winscp.exe /ini=C:\WinSCP.ini" SessionName1 /console /command "cd ""/home/username1/logs/uut/MN00093\IVT Gen2""" "get event* c:\tmp"
Regarding the bit about /defaults – what I mean is, if I for example use /synchronize parameter - if I dont specify the /default parameter, its gonna ask the user, whether I want to port to local, remote, which files to overwrite etc.
No. But you can run WinSCP with custom INI file with your preferences.
Carmageddon
Israel
Thank you! it works indeed :)
I still dont quite get why this works though, because the double-double quotes (according to the documetnation), are designed to escape a quotation character(use literally) - at least according to the explanation.
So, you might want to update the documentation along with an example, as this bit isnt quite clear:
Command parameters that include space(s) have to be enclosed in double-quotes. To use double-quote literally, double it:
Should be:
Command parameters that include space(s) have to be enclosed in DOUBLE-double-quotes. To use double-quote literally, double it:
And the example
Needs to be:
put ""file with spaces and ""quotes"".html""
At least that is the way you fixed the example in my case, and which actually works for me.
Again, thank you!
The double-double-quoting here is because of the command-line not because of the script, what the documentation refers to. This is not documented, but the behaviour is identical to the double-double-quoting in the script file. So the actual script command does not have any double-double quotes. If it had, there would had to be quad-double-quotes on the command line.
riyas_26
Applied two double quote yet no luck
I am using the below command and the local path is having space, so made it under two double quotes
But still I'm getting error
Too many parameters for command 'lcd'.
The file is getting downloaded in the same path where i am executing the script, not going to the path which I explicitly made under lcd.
Please help experts to fix it.
WinSCP version: 4.1.9 (build 416)
"C:\Program Files\WinSCP\WinSCP.com"
/log="d:\WinSCP.log" /ini=nul
/command "option confirm off"
 "option batch continue"
 "open sftp://testuser:password@20.20.20.20/"
 "cd /44/remotepath/2021/MAR/remotefolder"
 "lcd ""Z:\test path\2021\Mar"""
 "get REMOTEFILE.TXT" "exit"
confirm      off
batch        continue
Searching for host...
Connecting to host...
Authenticating...
The server's host key was not found in the cache. You have no guarantee that the
 server is the computer you think it is.
The server's rsa2 key fingerprint is:
ssh-rsa 2048 ************************
If you trust this host, press Yes. To connect without adding host key to the cac
he, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache?
(Y)es, (N)o, C(a)ncel, (C)opy Key: Yes
Using username "testuser".
Authenticated.
Starting the session...
Reading remote directory...
Session started.
Active session: [1] testuser@20.20.20.20
REMOTEFILE.TXT       |          0 KiB |    0.0 KiB/s | binary | 100%
Re: applied two double quote yet no luck
Your command-line seems ok. At least for the latest version of WinSCP. Note sure about 4.1.9, which is 12 years old. You urgently need to upgrade. If that does not help, post a log file on /loglevel=1.
marunachalam@...
FIlenames with space issue - need help
I have tried the sameway as written on this forum to pull the files with the spaces on the name. Nothing gets pulled.
I am running this via batch script
Following is the list of parameters passed to this batch script from Informatica
"FTPV|SeekingAcoustic|/download/|SeekingArrangement -*|E:\ETL\SeekingArrangements\WORKPROFILE\SourceFileList|OldestFirst|"
FOR /F "tokens=* USEBACKQ" %%F IN (`powershell -Command "[guid]::NewGuid().ToString()"`) DO (SET r=%%F)
echo %1 > %tmpdir%\%r%.ftplsseeking
REM var1=FTP Connection
REM var2=Remote FTP directory
REM var3=Filemask to list
REM var4=Local dir/name of list file
REM var5 = Sort Order "NewestFirst" or "OldestFirst"
REM ------------------------------------------------------
set var1=""
set var2=""
set var3=""
set var4=""
set var5=""
for /f "tokens=2 delims=|" %%A IN (%1) DO set var1=%%A
for /f "tokens=3 delims=|" %%B IN (%1) DO set var2=%%B
for /f "tokens=4 delims=|" %%C IN (%1) DO set var3=%%C
for /f "tokens=5 delims=|" %%D IN (%1) DO set var4=%%D
for /f "tokens=6 delims=|" %%E IN (%1) DO set var5=%%E
if %var1% == "" GOTO :ERROR4
if %var2% == "" GOTO :ERROR4
if %var3% == "" GOTO :ERROR4
if %var4% == "" GOTO :ERROR4
winscp.com /command "option batch abort" "option confirm off" "option echo on" "open %var1%" "cd /" "cd %var2%" "ls ""%var3%""" "exit" >> %tmpdir%\%r%.ftplsseeking
if %errorlevel% equ 0 GOTO :GOTIT
