cannot copy files with ":" from unix to win
psl
Hi!
I noticed that when a filename on unix server running sshd contains ":", WinSCP will not copy the file to PC. There is some error message about this but misleading. Do you care about such special characters in filenames??
With regards,
PSL
Re: cannot copy files with ":" from unix to win
There is option for this on copy confirmation dialog in "filename modifications" section. The option is switched on by default, you have probably switched it off. Does it help?
