synchronised browsing bug
TimBenjamin
I have recently upgraded to 4.2.5 from (I think) 4.1.x
Synchronised browsing no longer seems to work correctly. For example, I have the local directory set to C:\Work\SiteName\www and the remote directory set to /var/www/html/sitename
The contents of those two directories are identical.
Turning on synchronised browsing, with the local and remote directories set to those given above, and then attempting to browse to C:\Work\SiteName\www\docroot (for example) I get the following message:
Error changing directory to '/var/www/html/www/docroot'
Cannot get real path for '/var/www/html/www/docroot'
No such file or directory.
Error code: 2
Error message from server: No such file
Obviously, it should be trying to change to '/var/www/html/sitename/docroot' not '/var/www/html/www/docroot' - it replaces 'sitename' with 'www', and that is the bug I want to report.
I have tried various different paths in the "Directories" section of the session setup screen but to no avail. Clearly WinSCP is mapping the directories incorrectly, and it didn't do this before.
Re: synchronised browsing bug
Rhialto
Donor+
Québec, QC - CANADA
Same here, I recently upgraded to 4.25 and found that bug so I'm back with 4.24 beta and all is fine. I use the portable version.
When we double-click in the right pane (remote) sync works and the left pane follow.
It's when we double-click in the left pane that the sync does not work and we get the error.
Just curious, why this was working in all previous versions then suddenly stop to work? Introduction of a new feature maybe?
When we double-click in the right pane (remote) sync works and the right pane follow.
Will send you a debug version.
Correct. Synchronized browsing in 4.2.5 works even when changing to different directory branch in one step.
Rhialto
Donor+
Québec, QC - CANADA
oops, I edited my message to cerrect that line:
Have you tried it youself? It's when we double-click in the left pane that the error happen...
