"Once finished" Options from the command-line
Petros
Hallo everyone,
I use the command-line to synchronize two directories, eg:
winscp.exe [mysession] /synchronize [local_directory] [remote_directory] [/defaults]
Is there any way to set the "Once finished: shutdown" option, which is available in the graphical interface of the new WinSCP version, through the command-line?
Using WinSCP 4.2.5 with "Commander" interface on Windows Vista.
Many thanks in advance.
Re: "Once finished" Options from the command-line
Just shutdown the machine after the script finishes. You can use shutdown.exe, which is part of Windows.
Petros
And is there a way to automatically send the shutdown.exe command just after WinSCP has finished the synchronization of the directories?
Just run the winscp.exe (or .com) from .bat file and follow that by shutdown.exe.
