recover files that have been cleand from temp
pptt
hello,
when i use winscp to edit a file it show in the temp folder of my XP,after i close winsp the files are cleand up by winscp.
is there any chance to recover this removed files ? and if yes how ?
many thanx
Re: recover files that have been cleand from temp
The files are removed. So you can try to recover them the same way as other removed files.
pptt
thank you
thank you for your reply,
i did try with no success...i did succeed to recover old deleted aduult moviees in process :)
any recommended for recovering this files ?
many thanx
