command line syntax
pavel
command line syntax
hi,
it will be great to have oportunity of copying files through 'Send To' command of
standard windows explorer File-menu.
This require better command-line syntax of winscp, something like:
winscp /session=mylinux /CopyAndQuit source=c:\file dest=~/.
Is it problem to add command line syntax to winscp ?
thanx
pavel
Re: command line syntax
WinSCP can integrate to 'send to' menu by itself. Setup application can do it. Or see "Integration" tab of preferences dialog. To tie the menu item directly to particular stored session, see "Shell icon" button on "stored sessions" tab of login dialog.
