Silent install no longer working
adrian_vg
Uppsala, Sweden
Just tried to silently install the latest stable version of WinSCP; v4.2.5.
Using the info in the faq, I've been using the /silent and /verysilent switches as well as the /loadinf-parameter to automate installations. This no longer works.
Error is I get a popup saying "Please chose an option" and offers me to click OK, whereupon the installer shuts down.
This is the line in the install script I use:
    winscp425setup.exe" /VERYSILENT /NORESTART /LOADINF="winscp4.inf" /NOICONS /mergetasks="desktopicon\common"
I've also tried the bare-metal silent install with the same result:
    "winscp425setup.exe" /SILENT /LOADINF="winscp4.inf"
The contents of winscp4.inf below. I use /saveinf with the installer to create the answer-file:
    [Setup]
    Lang=en
    Dir=C:\Program Files\WinSCP
    Group=WinSCP
    NoIcons=1
    Components=main,shellext,pageant,puttygen
Can you advise please? If I forgot any information pertinent to this, please let me know. Thanks.
/Adrian_vg
adrian_vg
Uppsala, Sweden
Re: Silent install no longer working
Made a small typo when using the /SAVEINF-switch, below is the new contents of winscp4.inf.
    [Setup]
    Lang=en
    Group=WinSCP
    NoIcons=0
    SetupType=full
    Components=main,shellext,pageant,puttygen,transl,transl\eng
    Tasks=enableupdates,sendtohook,urlhandler,searchpath
Silent install however still gives me the "Chose option"-popup.
It works for me with /silent. Can you post a screenshot of the "Please chose an option" screen? Also log file from setup might be useful.
adrian_vg
Uppsala, Sweden
That was weird, just booted up my computer for the day and tried it again, and now it works... :roll:
Don't know if it had anything to do with the numerous uninstalls and installs of WinSCP while I was trouble-shooting or what. Should I encounter this again, I'll get back to you.
Sorry for wasting your time. :?
adrian_vg
Uppsala, Sweden
Re: reply
dr_john_eaton wrote:
Twat!
How incredibly mature. How old might you be then? :roll:
Anyway, I encountered the same problem again a while ago on a couple of machines at work. Only those few, all other worked fine installing the latest version of WinSCP. No big deal basically.
