Regarding the free space in target machine!
gopikrishnakomanduri
India
I am using winscp to do file transfer from my windows m/c to other unix m/c. Is there any way to check the free space available on that unix m/c before transfering the file or , if the transfer fails due to space contrains , can we be able to delete the created file till that moment?
I mean does , winscp support this feature ? I am using winscp.exe version 3.8.2.330 .
Thx,
--Gopi
India
Re:Re: Regarding the free space in target machine!
Thanks for the response. I ahve gone through the documentation. But the thing is I need to check for the space through script. does winscp has any such command?
One more query is , consider that my remote disk has 10GB space , but I am trying to transfer 11GB file . So ideally winscp fails to transfer once the disk if full. Now will that copied data be removed or will the data whatever that is copied remains like that ?
Thx,
--Gopi
No. Also support for checking free space it that rare among SFTP servers that it is hardly useful implementing it on a client side.
