Received too large (103188 B) SFTP packet. Max supported pac
Bitjunky
I was getting this error when connecting to a 3rd party sftp.. I was able to connect with Filezilla no problem and I deleted a few files (Was 770+) to about 750 and I was able to re-connect.. So apears that WinSCP has a problem with large Directories..
Re: Received too large (103188 B) SFTP packet. Max supported pac
